Author Topic: NQS BBK A Not Quite So Big Brake Kit..NQS Rear mods now.....  (Read 512892 times)
Re: NQS BBK A Not Quite So Big Brake Kit..NQS Rear mods now.....
« Reply #975 on: March 20, 2017, 01:38:40 pm »
Not quite...
If the PP piston is 50mm then the area is 1963.5mm2
If the 18Z pistons are 30/34/38 the the area is about 5500mm2
Unless I have made a huge maths fail
Offline mdmay
  • -Given: 38
« Reply #976 on: March 20, 2017, 01:50:25 pm »
To calculate the effective area you only calculate for one side not both as per a sliding caliper
Sent from my ONE A2003 using Tapatalk
Regards,
Mike
Offline Shoduchi
  • -Given: 220
  • -Receive: 430
« Reply #977 on: March 20, 2017, 01:52:26 pm »
Not quite...
Stock GTI/Ed. 30: ATE FN3 54 mm = 2290 mm²
R32/6R/S3 8P/TTS/Cupra mk2: ATE FNRG 57 mm = 2552 mm²
Brembo 18Z (30/34/38 mm): 707 + 908 + 1134 = 2749 mm²
GTI PP/Ed. 40/7R/S3 8V/Cupra mk3: TRW 60 mm = 2826 mm²
Those are my calculations. :confused:
Offline JamesED30
« Reply #978 on: June 09, 2018, 10:51:52 pm »
Anyone still running this kit??
Anyone selling this kit??
Offline Christiank
  • -Receive: 39
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110924.0.html
« Reply #979 on: June 10, 2018, 07:22:15 am »
I have it to both front and rear ..
My rear is the Caddy calipers with 41mm piston instead of the 37mm found on the GTI.
I'm having some trouble with my front kit since I'm running the alloy hubs from Cupa/S3/Passat. Hopefully it will possible to get a solution soon and have it installed
MK5 TDI 2.0 MY2005 - FULL OF RETROFITS:
MK6 dashboard - BCM converted - MK7 cruise control MFSW - PLA 2.0 - 3D instrument cluster - Discover Media 2 - Highline TPMS - 10ch Dynaudio system - KESSY with start button
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #980 on: June 14, 2018, 08:58:33 am »
you can buy them off johnny at brakecaliperrefurbs
Offline JamesED30
« Reply #981 on: June 20, 2018, 10:20:30 pm »
Your running the same calipers on the rear? Or the boxster rear calipers on the rear?
Offline JamesED30
« Reply #982 on: June 20, 2018, 10:26:41 pm »
Did any1 run S3/R32 splash shields with this kit?
Offline Christiank
  • -Receive: 39
« Reply #983 on: June 24, 2018, 06:57:26 am »
No, I run Porsche 986 front and VW Caddy calipers on the rear. Same size as the GTI caliper just with a larger piston in it.
Why run R32 splash guards when it'll fit with normal GTI 312 front / 288 rear guards?
Offline JamesED30
« Reply #984 on: July 04, 2018, 03:55:01 pm »
[/quote]
Cause my standard ones are shagged and I got them from VW for £19. 😂
Offline Christiank
  • -Receive: 39
« Reply #985 on: November 22, 2018, 03:23:20 pm »
Have fitted both front and rear NQSBBK setup for my mk5 .
Running with Vagbremtechnic J-hooked discs at all 4 whees with DS2500 pads.
Got a MASSIVE squeeking noice when braking, I've installed the anti rattle shims to hopefully could prevent this - but sadly they do make a lot of noise!
Anyone in here have runned with DS2500 pads for this setup? Need to hear if I should buy some Textar pads instead since my car will never see track :thinking:
Offline Blade3562
16" Fitment Questions
« Reply #986 on: December 31, 2018, 01:23:33 am »
So I'm another colonist with a Mk7/MQB chiming in. I read through the thread and am curious about the 16" fitment. My wheel choice is still up in the air, but I'm wondering if anyone has a good template or measurement technique for fitment? The only post with tips has missing photos. I'm planning to run them on my '17 GSW 4Motion that I'm lifting about 2-3"! There is a much better selection of 16" off road tires that fit than 17" ones so I'm hoping I can make these fit under some 16s. Currently the car has the OEM Toronto's(16x6.5 ET46, pretty flat mounting surface/spoke design). Thinking about running 1552s or some Sparco Terras.
I have some Neuspeed 6 pistons that use the OE 340mm rotors on my track car, but sadly they require 17s.
Offline Martyndg
« Reply #987 on: March 15, 2019, 08:14:08 am »
So I’m probably asking a question asked many times but o can’t find a definitive answer.
Front 986 calipers on mk5 golf with 18” Monza.
What spacers, if any, are required??
Many thanks
Offline colesey
  • -Receive: 89
« Reply #988 on: March 15, 2019, 09:02:25 am »
Offline LegendaryAllen
  • Newbie
« Reply #989 on: September 07, 2019, 09:37:15 pm »
Hi,
Looking for some help/advice.
I have recently come into possession of some Porsche Panamera Rear calipers (970352425) from what I’ve found out they run 330x28mm discs. I’m looking to run them as front brakes on my 2.0TDI Touran.
Now I understand it may not be conventional to run rear brakes on the front but as they are 4 pot brembos I figured it would still be an upgrade over the standard brake setup. I need an adaptor bracket. Can anyone shed any light on what bracket I need and where I can get it?
Is there anything else I need to know? Or do?
Thanks in advance
