Author Topic: NQS BBK A Not Quite So Big Brake Kit..NQS Rear mods now.....  (Read 475714 times)
Re: NQS BBK A Not Quite So Big Brake Kit..NQS Rear mods now.....
« Reply #840 on: March 10, 2014, 05:23:17 pm »
To me that says that the pad wasn't quite seated 100% parallel to the disc so the inside has worn more than the outside.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #841 on: March 10, 2014, 09:40:53 pm »
That was my impression also. But the J are not all gone all across the disc. Some parts of the disc are gone and others are not.
« Reply #842 on: March 10, 2014, 09:45:08 pm »
Well maybe the discs wasnt 100% true either. I shouldnt worry about it, most discs probably wear like this, its just that you are seeing it due to the hooks
Offline Been-0
« Reply #843 on: March 21, 2014, 10:12:15 am »
Hi I've read through most of this and was wondering what disc size the fronts are running? Also does anybody have any pic's of the NQS Rear?
« Reply #844 on: March 21, 2014, 10:16:16 am »
fronts are 312mm disc
Offline bacillus
  • -Receive: 451
« Reply #845 on: March 21, 2014, 10:28:16 am »
When installed on the car the NQS rear looks exactly like the oem ones.   :smiley:
Offline Tr0nic
« Reply #846 on: March 21, 2014, 08:13:22 pm »
Identical to oem only increased piston diameter
Milltek Catback Non Resonated - K&N panel filter with Carbonspeed, NQSBBK front, Caddy rears, CF engine cover, Bilstein B8 with Eibach Prokit, DS2500 all around
Offline Acidutzul
  • 2.0 TDI ~165HP daily&track
« Reply #847 on: March 23, 2014, 01:40:57 pm »
Vlad, take a look at the Tarox discs that Teo is unsing on his 345 Cupra brakes. Same wear pattern. I've seen it on other brakes also (and not all were single piston caliper).
https://www.flickr.com/photos/40672373@N03/13352962995/
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #848 on: March 23, 2014, 07:41:14 pm »
Difference is Vlads are a good 1/2mm plus thinner than design min thickness, the wear rate isn't linear and accelerates when thinner......
Some of the heat treatments can either involve firing or immersing in molten salt for a while, whichever method the hardening is obviously crunchy on the outside and soft on the inside.......armadillo!
Sorry back on topic....
They've done incredibly well....they need replacing.....they don't last for ever
Offline QD MBE
  • -Receive: 102
« Reply #849 on: March 23, 2014, 08:24:43 pm »
Having changed a few supposed race discs and pad sets in the last few years, these seem amazing.
Well done Prof Friction.   :congrats: :congrats: :congrats: :congrats:
all we need now are Proj Mu pads!
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #850 on: March 24, 2014, 06:17:38 am »
Yup, the wear seemed linear till this point and know I suspected the pads for causing this (RS 29).
Stefan, I've seen this problem with Eddy's Type R FN2 Stoptech bbk (he also has RS 29) but luckily for my my discs are much cheaper to replace  :grin:
Offline Acidutzul
Re:
« Reply #851 on: March 24, 2014, 04:52:03 pm »
Again, i don't see it as a problem :)
Sent from my GT-I8190 using Tapatalk
Offline matsu
  • -Given: 78
« Reply #852 on: March 24, 2014, 05:38:10 pm »
I know a lot of people  following this thread
I just ordered some new pads front for faves porker specials and std rears on faves recommendation
Outstanding help and service
Will def recommend him to anyone looking for brakes
Huge thank you Dave
Matsu :congrats:
Offline snowfree52
« Reply #853 on: March 28, 2014, 10:47:40 am »
Hello,
I just tried to mount the NQSBBK to my Audi A3 8V.
Good news is the caliper fits within the wheel.
Bad news is the adaptator doesn't fit !!! It touches the hub.
I took some pics.
Any help ?
DaveB do you do another adaptator that would do ? Or could I cut it a bit ?
  • Trader - 2014
  • -Receive: 130
« Reply #854 on: March 28, 2014, 04:32:14 pm »
Huge thank you Dave
Matsu :congrats:
Cheers Matey My Pleasure!
