Author Topic: PSI wheel sensors  (Read 1507 times)
Offline aidogti
PSI wheel sensors
« on: May 06, 2010, 10:17:27 pm »
hey lads im changing my standard oem alloys for reps and just wondering were are the psi sensors? are they in the valves? can i swap them to the reps?
 thanks for any advice lads...
Offline gazbutS3
Re: PSI wheel sensors
« Reply #1 on: May 06, 2010, 10:24:23 pm »
there are no sensors, the system works on the ABS sensors measuring the wheel speed so don't worry :happy2:
Offline Beddie
  • -Receive: 76
« Reply #2 on: May 06, 2010, 10:25:29 pm »
The TPMS on the MK5 works via the ABS system so doesnt have sensors  :happy2:
Carbon Grey Edition 35 - Here
Offline aidogti
« Reply #3 on: May 06, 2010, 10:31:14 pm »
ah thanks lads... appreciate it, i thou i read somewhere the sensors were in the valves :ashamed:
Offline bacillus
  • -Receive: 451
« Reply #4 on: May 06, 2010, 10:49:48 pm »
Yes, the US GTIs use a sensor inside the rim attached to the valve. They monitor actual tyre pressure vs ours that rely on the ABS sensors that monitors rolling circumference.
