Author Topic: URGENT Help needed please  (Read 9856 times)
Offline Jaywoo-GTI
  • -Given: 38
Re: URGENT Help needed please
« Reply #15 on: May 07, 2010, 01:45:53 pm »
Having a similar problem on my revo stage 1 gti, Does anyone have the part number and rough price for the sensor?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #16 on: May 08, 2010, 07:48:36 pm »
Sensor did not fix the issue, so more work needs to be done on our return to the UK.
Offline bacillus
  • -Receive: 453
« Reply #17 on: May 08, 2010, 08:12:51 pm »
That is a bummer...
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #18 on: May 08, 2010, 08:16:06 pm »
Yep the car is currently at a VW dealer we found in Belguim. They are looking after it until we collect it on the way back.
We have a few more things to check on the return when we collect the car.
Offline chungster
« Reply #19 on: May 08, 2010, 08:48:07 pm »
Did the owner have the option to switch it back to stock mode to see if problem still persisted??
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #20 on: May 08, 2010, 09:39:59 pm »
No not stock mode available otherwise that would have been the first step as I know this fault can be triggered if too much boost is requested.  :happy2:
« Reply #21 on: May 09, 2010, 12:16:57 am »
I'm afraid it's another example of the benefits of having a Revo map (or APR) - The option to change to 'stock' or change settings.
I feel really sorry for who's car this is - They must be really gutted not to get their car to the Ring.
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #22 on: May 09, 2010, 08:27:52 pm »
A quick test with a known good working low pressure fuel sensor "appears" to have remove the fault, so a replacement is currently being collected.
There was a TSB for this - did yours miss this?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #23 on: May 09, 2010, 08:33:34 pm »
The sensor was not at fault in the end. The problem still persists after replacing it.
« Reply #24 on: May 10, 2010, 12:00:27 am »
I'm still edging towards my first diagnosis of a HPFP fault/failure.
Offline markymark
« Reply #25 on: May 24, 2010, 08:40:12 am »
Well after having the MAF replaced I thought my troubles had gone away but alas the problem has come back again. Do you think its my car saying it needs an uprated HPFP? I took the car back to the dealers and its coming up with exactly the same fault code again.
According to the VAG diagnostics it could be either Camshaft lobe wear or fuel pump? I hope its not the camshaft as thats a 6 hour job and at dealer prices :surprised:
Any help would be appreciated, the dealers cant fit it in till 7th June so until then I dont want to use it! :sad1:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #26 on: May 24, 2010, 09:12:20 am »
Get the map taken off and see it the problem remains Mark.
Offline markymark
« Reply #27 on: May 24, 2010, 09:17:08 am »
If it still remains what would that suggest? Still pump related?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #28 on: May 24, 2010, 09:17:55 am »
Yes I would think it then does point towards the pump or the high pressure sensor on the fuel rail.
Offline markymark
« Reply #29 on: May 24, 2010, 09:24:37 am »
Cheers Steve, I will try and get the map taken off and then try it. If the fault doesnt occur would that still indicate fuel pump?
