Author Topic: Hi all  (Read 4311 times)
Re: Hi all
« Reply #15 on: December 29, 2012, 10:52:33 pm »
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
Re: Hi all
« Reply #16 on: December 29, 2012, 10:57:09 pm »
SEAT LEON MK2 TFSI SPORT KO4 *updated* (BYD engine! unknown mileage (clocks 105K... 06)
revo stage 2+ map (BOOST 7 - TIMING 5 - FUEL 9)
works well for my car - silky smooth as they say lmao...
My Leon isn't complete...My "unique" APR file needs to be re-calibrated (I'll explain a little more later!)
3" Eurojet TBE
Forge twintake CAI + Ducting to the fog lights!
APR FMIC
Autotech HPFP
OEM 2.0T Upgraded Diverter Valve - G Version!
Forge BOV Spacer - SOLD
Neuspeed Hi-Flow Turbo Discharge - Refined for the K04
Neuspeed Power Pulley Kit
Neuspeed Hi-Flow Intercooler Pipe
Neuspeed Shortshift + 42Draft Solid Shift Bushes
Neuspeed Engine Torque Arm Insert + New Bolt
Eibach Sportline Springs
225/45/17 94Y Goodyear F1 Eagle's As
Select Plus Switch
RS4 Fuel Valve
oem audi red coil packs
oem spark plugs - NGK Iridium X (from Awesome)
MK2 PRE-FL SEAT LEON TFSI SPORT - APR K04
Re: Hi all
« Reply #17 on: December 29, 2012, 11:47:26 pm »
So its a stock k04? Essentially Stage 2+ ?
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
Re: Hi all
« Reply #18 on: December 29, 2012, 11:50:36 pm »
K03 to K04 Converted essentially... Stage3
(Was on 2+ with K03)
Re: Hi all
« Reply #19 on: December 29, 2012, 11:52:10 pm »
Ok.. i get you.  :happy2:
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
Re: Hi all
« Reply #20 on: December 29, 2012, 11:53:35 pm »
My bad mate, it's late and my last reply was vague to your question! zzz
Re: Hi all
« Reply #21 on: December 29, 2012, 11:55:20 pm »
All good... i understood!
Offline cheungy
  • "GO APR!"
    • SeatCupra.net
Re: Hi all
« Reply #22 on: August 10, 2013, 11:56:25 pm »
..... whats the updated spec?
TFSI Sport 06 Model (not FR and not Cupra just a Sport!)
BYD Engine
K04 Turbo
S3 Injectors
Eurojet 3" Turbo-Back Exhaust System
Forge Twintake CAI
Forge Oil Catch Can
APR Front Mount Intercooler
Autotech 2nd Gen Fuel pump internal
RS4 Fuel Valve
Devil's Own Stage 2 Water Meth + Progressive Controller
Devil's Own eletronic Solenoid Valve
Devil's Own Stainless Steel Lines
INA Water Meth Spacer Plate (Post Throttle Body)
Cheungy's 30% Meth Mix *Good sh*t*
Newsouth Redline 30PSI Boost gauge
Nology Silver Sparkplugs
Audi Red Coil Packs
Neuspeed Discharge Pipe
Audi TTS Engine cover in Tornado Red
SACH Stage3 Sintered Clutch
LOBA Single Mass Flywheel
Draft42 Solid Bush Link
ECS Bleeder Block
Neuspeed ShortShift
Millers CRX 75w90 NT Gearbox Oil
vibra-technics Gearbox Mount
vibra-technics Side Engine Mount
vibra-technics Lower Dogmount Bush
Powerflex Black Edition Dogmount Insert
Porsche Boxster 986 Brakes (NQSBBK)
H&R 8MM Spacers Front
FK 20MM Spacers Rear
Goodyear F1 Eagles Assy 2 All Round 225/40/18 92Y
FR Front + Rear Bumpers
Triple R Front Splitter (or what's left of it...because RaceCar!)
Never too late?  :innocent:
