March 12, 2025, 09:19:56 pm
All Things Mk5
Mk5 General Area
Replacing front fog light
Topic: Replacing front fog light (Read 13588 times)
Russ_leeds
Won't Shut up.
-Given: 24
-Receive: 16
May 25, 2010, 11:19:13 pm »
Is it possible to change the fog light without removing the full bumper? mine got smashed when driving so need to replace. is there a how to guide? tried searching to but no luck?
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
bacillus
Just look at my post count
-Given: 4
-Receive: 451
Re: Replacing front fog light
Reply #1 on:
May 25, 2010, 11:29:21 pm »
Just remove the one screw holding the fog grill in, pull out the grill and you can then remove the fog light.
iirc it's held in place by three screws.
McKay88
Always Involved
-Given: 1
-Receive: 2
Reply #2 on:
May 25, 2010, 11:30:45 pm »
Nope just need to remove the fog light cover which is a 20 torx i think then it will just pop off... Behind that their will be 3 25 torx holding the fog light in. Just unplug and then install the new one.
Should only take 5 mins very simple..
Hope this helps
bacillus
-Given: 4
-Receive: 451
Reply #3 on:
May 25, 2010, 11:32:12 pm »
This should help.
http://www.golfmkv.com/forums/showthread.php?t=130
Russ_leeds
Won't Shut up.
-Given: 24
-Receive: 16
Reply #4 on:
May 25, 2010, 11:34:30 pm »
cheers guys
much appreciated
All Things Mk5
Mk5 General Area
