Author Topic: Recaro (1K0 010 615 K ?) and other info needed....  (Read 20804 times)
Offline animal
  • .:R32
Re: Recaro (1K0 010 615 K ?) and other info needed....
« Reply #15 on: May 29, 2010, 11:29:21 pm »
Robin, removing parts #10/11/12 is surely going to leave a gaping hole in the cut-out where the release handle is meant to be located? You'd probably be better of bonding them in place some how so that they can't rattle without the tension of the cable.
« Reply #16 on: May 29, 2010, 11:29:42 pm »
I am by know means sure, but i  think its a case of under serious g-force the seat collapses. I dont think the force will just lift the latch.  :smiley:
Imagine  yourself sat their and there is no seat back at all, just you being held in by the harness. If you then had a head on crash your top half would still go forward but downwards as well because your shoulders would just burn on the strap and compress you downwards. Side fixings eliminates this.  :popcornsoda:
I could easily be talking sh*t though.  :laugh:
Offline animal
  • .:R32
« Reply #17 on: May 29, 2010, 11:41:45 pm »
For what it's worth I agree, but at the end of the day, what RR wants to do is entirely up to him. As I've said before, this isn't like fitting an illegal HID kit or dodgy brakes pads that could have profound consequences for other people on the road (i.e. possibly even cause an accident) - This is a track only mod that is never (in theory) going to effect anyone other than Robin.
To quote RR himself - ETTO :drinking:
« Reply #18 on: May 29, 2010, 11:55:08 pm »
There are a few of us using these harness's, with Recaro's  and indeed with normal seats, but still on a 3 door so i am very interested as well, in finding a solution. I just think it is going to be a big undertaking dismantling the seat and stripping out the mechanism + adding in some sort of fixed version.  :smiley:
« Reply #19 on: May 29, 2010, 11:58:06 pm »
....Yes, that occured to me as well. But I think that if either of or all of parts #10/11/12 are removed, #13 lines the slot.
Bonding is another alternative. We won't know until we (me! or rather, my coachbuilder friend) take the seat apart.
« Reply #20 on: May 30, 2010, 12:02:41 am »
....Tedious and fiddly but not a big undertaking, according to those I've spoken to who have dismantled Recaro's.
There's nothing to be added to the seat as far as I can tell (also confirmed by TTshop) because the cables operating the tilt mechanism should be able to be unattached hence leaving the seat back locked.. rigid.
« Reply #21 on: May 30, 2010, 12:07:34 am »
We are going round in circles, you are not getting my point, whether i am right or wrong.
 In simple terms i am saying there may be a weakness in the actual point that tilts at the bottom and not in the workings of what makes it tilt.  :rolleye:
« Reply #22 on: May 30, 2010, 12:11:17 am »
....But harnesses work differently from inertia belts. Also, I will probably have a harness bar in my half-roll cage.
I think it's worth investigating if the safety aspects of our Recaro's can be improved when used with a trackday harness. It's still early days.
« Reply #23 on: May 30, 2010, 12:16:09 am »
....Yes, I am aware of the potential weakness at the bottom 'hinge' but that area is just as vulnerable in all the tiltable oem seats when a harness is used and we have already established that the Schroth with oem seat combination, as tony_danza's, is TUV approved and that the label which started all this points towards the tilt release as being the issue.
« Last Edit: May 30, 2010, 12:19:46 am by RedRobin »
« Reply #24 on: May 30, 2010, 12:49:30 am »
y dont u just call recaro and ask them about the harness holes  :smiley: they should know as they will have tested the seats  :smiley:
« Reply #25 on: May 30, 2010, 12:59:20 am »
....Recaro's sole agents in the UK deal in zillions of different manufacturer's seats and aren't very knowledgable - It's like talking to a warehouse where the staff don't have a clue what's in the boxes they shift.
Perhaps an email to Recaro in Germany may get better results.
Btw, Recaro use the reference *cccls* (CCCLS) for our GTI seats.
Offline ashley
« Reply #26 on: May 30, 2010, 09:26:34 am »
Agree with TC. Its the fact that the harnesses work differently that causes the issue in the first place. How about swapping the drivers side to a rigid back seat such as a pole position that is actually designed for a harness. Only takes 2 min to swap ready for a track day and would be a weight saving?
Otherwise just take the risk. We all take risks everyday and are still on here to post :happy2:
Offline ashley
« Reply #27 on: May 30, 2010, 09:29:16 am »
Agree with TC cant see removing the release mech making it any stronger. Its the fact that the harnesses work differently that causes the issue in the first place. How about swapping the drivers side to a rigid back seat such as a pole position that is actually designed for a harness. Only takes 2 min to swap ready for a track day and would be a weight saving?
Not doubting your methods RR, I think its great your putting it out there for discussion.
« Reply #28 on: May 30, 2010, 12:00:04 pm »
....A Recaro Pole Position, or similar, is my last resort - First I want to see if I can adapt my existing CCCLS Recaro and avoid the extra expense and storage. My garage is tight and at the very far end of my property so I'm thinking of the practical.
[Thinks]: Could I reupholster just the seat cushions in Interlagos on a Pole Position?
Am in the middle of drafting an email to Recaro in Germany.  :happy2:
« Last Edit: May 30, 2010, 12:08:08 pm by RedRobin »
Offline paulk
« Reply #29 on: May 30, 2010, 12:35:30 pm »
is there no way to put a lock pin through the handle stopping it from bein used and locking it in place, then it could be removed when not on a track..
