Author Topic: VW Soundpack speakers?  (Read 14060 times)
Offline tony_danza
  • -Receive: 112
« on: January 19, 2009, 03:27:30 pm »
Are these basically the speakers from the Soundpack? I was thinking they might be a little bit better OEM wise for if/when I get an RNS510.
Could anyone locate the VW part number, as I suspect as usual they're cheaper from the dealer than ebay?
http://cgi.ebay.co.uk/VW-SPEAKER-UPGRADE-KIT-GOLF-MK5-PLUS-gamma-beta-sony_W0QQitemZ200298460168QQihZ010QQcategoryZ75319QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
Sideways yo!
Re: VW Soundpack speakers?
« Reply #1 on: January 19, 2009, 03:36:45 pm »
If you can afford aftermarket speakers, go for them instead. VW speakers (even the soundpack ones)aren't very good by any measure. The newer dynaudio upgrade that VW have started doing is much better. For best results go for an aftermarket head unit too :happy2:
« Reply #2 on: January 19, 2009, 03:42:10 pm »
If you don't want to faff around with things like baffles and such, Rainbow produced some speakers for VW mk5 Golf and they're designed to be a straight swap.
Offline tony_danza
  • -Receive: 112
« Reply #3 on: January 19, 2009, 03:43:15 pm »
Are there any details of the Dynaudio parts knocking about yet?? I don't want/need anything silly - just nicer sounding.
Looking at another Becker as an alternative, but I do like the OEMness of the RCD/RNS-510 and its linked functions to the computer/MMI link.
Sideways yo!
« Reply #4 on: January 19, 2009, 03:46:32 pm »
I've not seen any ebay sales on them yet, but the Dynaudio pack sounds decent in the Passat. Not heard it in the Eos though. I can entirely understand your OEM+ fetish too :happy2:
« Reply #5 on: January 19, 2009, 03:56:06 pm »
you cant beat the RNS 510 for OEM'ness. ass a JL cleansweep and amp to that and you have sound quality to match any aftermarket HU.
The RNS 510 deserves the JL cleansweep cos its sooo nice!
Offline tony_danza
  • -Receive: 112
« Reply #6 on: January 19, 2009, 04:07:05 pm »
The Rainbow stuff sounds interesting, Dynaudio would be the ideal - basically so long as it's not too expensive and sounds ok, as this will be a fit and forget mod, so it has to be OEM+. No custom installs etc..
Amps and subs are well off my radar Jay! you can only listen to radio 2 so loudly!!
Sideways yo!
« Reply #7 on: January 19, 2009, 04:16:33 pm »
I'd rip all my speaker out if I had to listen to Radio 2 all the time :signLOL: :rolleye:
Offline tony_danza
  • -Receive: 112
« Reply #8 on: January 19, 2009, 04:19:08 pm »
Get out!.. bit of Wogan on the way into work, superb.
Sideways yo!
« Reply #9 on: January 19, 2009, 05:20:35 pm »
haha! well...at least your over the hill rather than buried under it! ;)
« Reply #10 on: January 19, 2009, 05:24:37 pm »
It's rainbow's IQ line that fit VW Golfs mkv without adjustment:
IQ 220.25 Front - VW Golf 5
2-Way Component system
8 inch Woofer
Max. 150 Watt
Part number: 231221
Factory location: Front door, Mirror triangle or Rear door
IQ 320.25 Front - VW Golf 5
3-Way Component system
8 inch Woofer
Max. 180 Watt
Part number: 231403
Factory location: Front door, Dashboard, Mirror Triangle
IQ 165 CX Rear - VW Golf 5
2-Way Coaxial system
6.5 inch Woofer
Max. 120 Watt
Part number: 231550
Factory location: Rear door[/b]
« Reply #11 on: January 19, 2009, 05:27:34 pm »
v pricey!
450 for the front! bet there great tho, theres no point spending that on 3 ways if your not going to amp them tho
Offline tony_danza
  • -Receive: 112
« Reply #12 on: January 19, 2009, 06:43:52 pm »
Pah! big portion of nuts to them, I've better things to spend £450 on!!
Sideways yo!
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #13 on: January 19, 2009, 07:34:41 pm »
IMHO Your only going to see the full benefit of the Dynaudio stuff if you source the full amp setup, I am keeping my eye out for an Eos being broken for spares with this option as like Hurdy said in the Passat it sounds very good  :smiley:
What age is your car Mike?
It's an older model then you might already have the 10 speaker setup which combined with the RNS/RCD-510 will produce a noticably better sound than the RCD-300.
If you have only got the 8 speakers
Offline garethmk1
« Reply #14 on: January 19, 2009, 11:40:00 pm »
I've got the RCD510 with the 10 speaker soundpack, also has some sort of amplifier under the passenger seat - sounds ok actually, not bad for a factory setup.
Mk5 Golf GTi Edition 30 No:- 2101, 3Dr, Tornado Red, Rear Tints, RCD510 & Sound Pack, Arm Rest
Mk1 Golf GTi 16v Helios Blue, Too Many Mods To List .... MY First Car ! Owned Since 1996 !!! NEARLY READY !!!!!
