General > Product Reviews
Neuspeed rear anti roll bar and neuspeed drop links
<< < (7/7)
xxx_mojo_xxx:
It's been three weeks since I've had the H&R ARBs installed.  I've developed a peculiar knocking noise - which just so happens to occur when turning aggressively left or right from the rear.  Some times the knocking can happen by simply going over a slightly uneven road.
* From what I read in this thread..are the NeuSpeed drop links likely to resolve this issue?
Has anyone had any problems with them?
What other alternatives are there out there (i.e. to Neuspeed)?
Also, can you get drop links for the fronts?
MAT ED30:
Kw do front drop links for the clubsports coilovers
xxx_mojo_xxx:
Ordered a set of BSH drop links.  Thanks for the tip MATT ED30 :drinking:
I'll keep everyone posted on how things go once I get them in the next couple of days...
SteveS:
Bit old i know, but...
I wonder if this is my issue with wheel hop and noise.. I don't believe my front droplinks were changed. I should check to make sure there not broken also.
They are the eibach ones. Do they do drop links? (googling now)
xxx_mojo_xxx:
--- Quote from: xxx_mojo_xxx on October 09, 2009, 11:24:27 pm ---It's been three weeks since I've had the H&R ARBs installed.  I've developed a peculiar knocking noise - which just so happens to occur when turning aggressively left or right from the rear.  Some times the knocking can happen by simply going over a slightly uneven road.
--- End quote ---
Just to put this mystery to rest... turned out that one bolt was slightly loose on one of the rear shocks.
Navigation
[0] Message Index
[*] Previous page
Go to full version
