All Things Mk5 > Revo Zone
What Settings Could I Run With Revo Stage 1 If I Got A Fuel Pump??
Phil_T:
--- Quote from: vRS Carl on June 03, 2010, 10:18:11 pm ---
--- Quote from: Phil_T on June 03, 2010, 09:19:03 pm ---Did some logs other nite on what revo set B6 T6 F9 the Cylinder Timing was -6!!! on one cylinder it was also on -5 too
--- End quote ---
I would start on settings B6 T4 F6 and if all is ok then start gradually increasing them 1 step at a time
--- End quote ---
Are you saying start off on that with a standard fuel pump or uprated one? As i now have the autotech pump fitted
vRS Carl:
Yes start of on that with a standard or HPFP.
It's better to start safe and gradually increase than go the other way :happy2:
Phil_T:
--- Quote from: vRS Carl on June 04, 2010, 08:53:27 pm ---Yes start of on that with a standard or HPFP.
--- End quote ---
Cheers, will do doing some logging today before I set off to Modball next week!
Phil_T:
Did some logs today and ended up having to stick with B7 T5 F7 with a little pull back on one of the cylinders for a few seconds. Tried upping the boost to 8 which felt alot better but it was pulling back quite abit :(
Do you think its because ive still got standard exhaust and stage 1 map?
vRS Carl:
It could be any no. of reasons.
IIRC when i first went on to Stage 1 i was on settings B7 T5 F7 so that sounds about right :happy2:
You could try lowering the fuel setting to 6 and seeing if you can up the boost then. To be honest though it wont gain you much going up one boost level - maybe 5bhp & 5-10 lb/ft.
If you want me to have a look at the logs just PM me and i'll give you my email :happy2:
Navigation
[0] Message Index
[*] Previous page
Go to full version
