April 28, 2025, 06:39:27 pm
All Things Mk5
Performance Modifications
Fitting new roll bars
Topic: Fitting new roll bars (Read 1332 times)
geordie56
Won't Shut up.
-Given: 2
-Receive: 6
June 02, 2010, 06:14:12 pm »
Anyone fitting new roll bars may want to know that the rear is a doddle and the frot isnt to bad apart from the clamp i have showed in the pic below. Once oem bar is removed you have to reuse the front clamp however the rear pne new clamps are supplied which is sh*te. This is due to the fact the clamp looks like 2 pices so you think ok easy. however in reality it is one piece that has to be broken apart and then as you refit the bar you have to hold the nut on the top as you try and bolt it down through the subframe which is a pain in the ass! Is this the same as the golf then?
Janner_Sy
Just look at my post count
-Given: 62
-Receive: 113
Re: Fitting new roll bars
Reply #1 on:
June 02, 2010, 06:17:46 pm »
same deal on the octavia as well.
do any of the manufacturers supply new clamps with their ARBs. that could persuade me to go with them. getting the original bushes back under the clamps was a ninja test on mine
gazbutS3
-Given: 52
-Receive: 55
Reply #2 on:
June 02, 2010, 06:30:22 pm »
same as the S3
All Things Mk5
