Author Topic: What to apply to rear badge?  (Read 10043 times)
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« on: June 05, 2010, 10:26:27 am »
My rear badge has got white worm so its time to replace it. When i get the new one should i apply anything to it to try and prevent any further corrosion?
Offline matsu
  • -Given: 78
Re: What to apply to rear badge?
« Reply #1 on: June 05, 2010, 12:29:12 pm »
yeah carbon heehee :evilgrin:
matsu
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #2 on: June 05, 2010, 12:30:03 pm »
new revision rear badge can't get white worm, a 2 piece design   :happy2:
Over the top mod list ;o)
Offline Tuffy
« Reply #3 on: June 05, 2010, 05:21:33 pm »
As above mate. Wont happen with new badge. I replaced my old one as it suffered from the dreaded white worm.
Fairly easy job to do, worse part was removing the wiper arm! some people say you dont have to totaly remove the wiper motor, just losen it and turn it to get to one of the screws thats holding the boot badge/handle in place.
Offline Mr Punch
  • Has Pulled Cables At A Resonable Level
« Reply #4 on: June 05, 2010, 05:24:18 pm »
Mine has got the White worm what do you mean by 2 piece.....apart from it being in two pieces  :signLOL:
How much do they cost...... could I fit it?
I Always Wanted A Black Golf GTI Now I Have One...Yippee
Online stealthwolf
« Reply #5 on: June 05, 2010, 05:31:03 pm »
I believe on the earlier models the VW badge was all one piece ie the black base and the silver bit are all one piece. On later models, you can separate the silver VW bit from the black base. This silver bit can then be wrapped or painted a different colour.
  • -Given: 380
  • -Receive: 442
« Reply #6 on: June 05, 2010, 05:34:13 pm »
So although separable in two pieces can't the silver piece still get white worm?
Even the Monza wheel centre caps can get white worm! :fighting:
Offline Mr Punch
« Reply #7 on: June 05, 2010, 05:38:41 pm »
Sorry Wolf......what is wrapped
Online stealthwolf
« Reply #8 on: June 05, 2010, 05:39:07 pm »
As usual, I'm talkin about things I don't have a clue about. Just something I remember.
I'm sure about ten other people know the proper answer.
I think I'd better head back indoors. The sun's getting to me a bit.
Online stealthwolf
« Reply #9 on: June 05, 2010, 05:40:50 pm »
Punch have a look at a few of the members rides. The VW bit can be wrapped in carbon fibre or it can be painted to give it a different look.  The VW emblem can be separated. This is what is meant by two piece and I believe doesn't suffer from white worm.
Offline Tuffy
« Reply #10 on: June 05, 2010, 05:44:05 pm »
Think they are about £95 ish from vw but put a post in the wanted section as people who fit the rear reversing camera will have a boot badge/handle going spare. Fairly easy to fit, will take you about 1hr
  • -Given: 243
  • -Receive: 154
« Reply #11 on: June 05, 2010, 07:35:56 pm »
1 model:
white worm model i stanced from one piece of metal, lower areas painted black upper areas polished the clear laquer on top, which enables white worm to appear.
Look carefully and you will see the "tap" that holds the metal logo to the handle
2 Model:
Black plastic bottom with small holes to fit chrome plastic VW logo on top of.
« Last Edit: June 05, 2010, 07:46:43 pm by danishmkvgti »
Offline Mr Punch
« Reply #12 on: June 05, 2010, 08:06:32 pm »
Thanks Stealthwolf :happy2:
Offline Mr Punch
« Reply #13 on: June 05, 2010, 08:09:43 pm »
1 model:
2 Model:
Thanks I understand more now  :happy2:
Offline bodger00
  • -Receive: 20
« Reply #14 on: June 06, 2010, 09:56:54 am »
Cheers guys just dont want the same thing to happen when I replace mine. If the newer badge does not suffer then i suppose i have nothing to worry about :smiley:
