December 19, 2025, 09:36:13 am
All Things Mk5
Mk5 General Area
Puncture with a BBK
Topic: Puncture with a BBK (Read 2321 times)
xxx_mojo_xxx
Just look at my post count
-Given: 39
-Receive: 19
MUBster DUBster
Puncture with a BBK
July 05, 2010, 12:16:26 am »
What would you do if you got a puncture and you had a BBK fitted on the front?
Presumably, the standard space saver wheel would not fit?
Top Cat
Top cat
-Given: 171
-Receive: 335
Almost Jacamo
Re: Puncture with a BBK
Reply #1 on:
July 05, 2010, 12:19:17 am »
use the rear wheel for the puncture and put the space saver on the rear.
xxx_mojo_xxx
-Given: 39
-Receive: 19
MUBster DUBster
Reply #2 on:
July 05, 2010, 12:23:35 am »
Thanks TC.
Wots ur preference...should get a spare Monza II and carry it in place of the space saver... not too keen on the adding extra weight though.
Also, I'm assuming it would fit in the back.
Top Cat
Top cat
-Given: 171
-Receive: 335
Almost Jacamo
Reply #3 on:
July 05, 2010, 09:03:24 am »
I carry the space saver its fine to get you to the garage.
tony_danza
-Given: 3
-Receive: 112
The voice of objective reason, but mine's best.
Reply #4 on:
July 05, 2010, 09:04:29 am »
I agree on just swapping a rear, but a full sized alloy probably weighs less than the space saver, you'll need the R32 boot inserts though to lift the false floor.
Buy a cheapo 17" Monza, job done.
Sideways yo!
xxx_mojo_xxx
-Given: 39
-Receive: 19
MUBster DUBster
Reply #5 on:
July 05, 2010, 11:00:02 am »
Can you explain about what the false floor and R32 insert thingy is all about...? Thanks, Mo
tony_danza
-Given: 3
-Receive: 112
Reply #6 on:
July 05, 2010, 11:36:27 am »
I haven't got a pic, but basically the R32 has 2 polystyrene inserts that sit on the boot floor either side of the wheel to raise the false floor/carpetted cardboard thing up high enough to clear the spare.
Make sense?
Sideways yo!
Hedge
-Given: 484
-Receive: 304
Reply #7 on:
July 05, 2010, 11:37:35 am »
The R32 doesn't have a full size spare its just it has an elevated boot floor thanks to the 4WD.
JPC
-Given: 93
-Receive: 111
Reply #8 on:
July 05, 2010, 11:43:03 am »
You can run a full size spare if you have the inserts.
Also, the R32 has a much more rigid boot carpet IIRC. without this, its a bit of a mess using the floppy boot carpet from the GTIs
xxx_mojo_xxx
-Given: 39
-Receive: 19
MUBster DUBster
Reply #9 on:
July 05, 2010, 11:51:44 am »
Anyone got photos from an R32 so I can visualise this...
All Things Mk5
Mk5 General Area
Puncture with a BBK
