Author Topic: How to confirm HPFP?  (Read 9195 times)
Offline S2 Ant
  • -Receive: 21
« on: July 20, 2010, 08:40:30 pm »
Another trivial question asking for help....
Recently bought an APR HPFP from the bay - item is a complete fuel pump with upgraded internals.... apparently.... How could i confirm the parts are what they are said to be?
Is there a test or are any parts stamped differently?
Ant
Offline Poverty
  • -Given: 36
  • -Receive: 21
Re: How to confirm HPFP?
« Reply #1 on: July 20, 2010, 08:43:05 pm »
should have a apr sticker on the housing.
Offline Janner_Sy
  • -Receive: 113
« Reply #2 on: July 20, 2010, 08:44:31 pm »
i could stick a sticker on a pump.  it doesnt make it an APR one though.
@ the op  speak to JKM or awesome GTI.  they deal with apr pumps and might be able to help you.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #3 on: July 20, 2010, 08:54:34 pm »
Post a picture of it
But the only true way would be to separate the piston from inside and see if it's larger than the OEM one
Offline Janner_Sy
  • -Receive: 113
« Reply #4 on: July 20, 2010, 08:55:36 pm »
or log the rail pressure before and after fitment
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #5 on: July 20, 2010, 08:57:05 pm »
yes but where would you get the right apr sticker from. If there is no sticker then we can know pretty much straight away that its not a APR pump.
There are other differences to the APR pumps compared to the others but the sticker is the most obvious, and once we have ruled on the sticker we can then move on to the more technical bits if necessary
Offline S2 Ant
  • -Receive: 21
« Reply #6 on: July 20, 2010, 09:07:38 pm »
I've sent a message to Awesome to see if they're able to help at all.
It should be internals only, so sticker or not wont count for much if he installed the internals himself.
Ideally i want to know if genuine or not without the hassle of fitting first too
This any use? Should be full size so might be annoying to view
Edit: Forum has resized, if you open the link to the image it'll be larger.
« Last Edit: July 20, 2010, 09:19:12 pm by S2 Ant »
Ant
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #7 on: July 20, 2010, 09:19:24 pm »
APR pumps come complete, unlike other kits where you upgrade the internals yourself.
Do you have a link to the original ebay page?
Offline gazbutS3
« Reply #8 on: July 20, 2010, 10:15:55 pm »
I got a std fuel pump in my hand right now, and have been comparing with pics of your pump and pics of APR pumps on t'interweb hoping there would be an obvious difference on the shaft/spring/plunger but unfortunately theres nothing that jumps out at me :smiley:
Offline neg
  • gone old skool
« Reply #9 on: July 20, 2010, 10:37:52 pm »
VCDS is the only way really as stated already
Offline gazbutS3
« Reply #10 on: July 20, 2010, 10:40:30 pm »
just had another look and noticed in all the images of the APR pumps I looked at the pump shaft is black, which is APR's diamond like coating apparantly :laugh:, where as the picture shown and the std pump in front of me has a silver shaft, not sure this could be considered conclusive, just something I noticed
Offline Kuro
« Reply #11 on: July 20, 2010, 10:45:08 pm »
Here's a pic of mine I have for sale...
Don't know if that helps... Its not been fitted so if you want me to look closer at anything give me a shout...
Offline Kuro
« Reply #12 on: July 20, 2010, 10:46:11 pm »
Mine is an APR HPFP and its black too...
Offline gazbutS3
« Reply #13 on: July 20, 2010, 10:46:23 pm »
^^^^^look a black shaft :laugh:^^^^^
Offline Gti_Mad
« Reply #14 on: July 20, 2010, 10:47:33 pm »
^^^^^ notice how u spotted the black shaft of all things  :evilgrin:
