Author Topic: S3 rear alloy hubs ATTENTION!!!!!!!  (Read 9404 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« on: July 21, 2010, 06:13:05 pm »
To anyone considering fitting the S3 rear hubs on a non 4wd car, the wheelbearings need the driveshafts to be held in place.
DO NOT fit them without a solution to this, the wheel, brakle disc and wheelbearing will reattach itself from the car and only be held in place by the disc being inside the caliper.  :mad:
 :smiley:
Over the top mod list ;o)
Offline laurent.d
Re: S3 rear alloy hubs ATTENTION!!!!!!!
« Reply #1 on: July 29, 2010, 07:43:51 pm »
I didn't know S3 hubs were alloy!!
Did you find a solution to fit them?
I wonder if leon Cupra rear hubs could be alloy or not?
A3 2.0 tfsi DSG S-Line/VWR K04 Turbo kit/Engine Revo Stg 3/Milltek Exhaust/DSG Revo Stg 2/Quaife LSD/Bilstein PSS10/H&R sway bars/Power Grip Morego/VWR Suspension Bushes/VF Engineering Engine Mounts/VWR Lower Mount/OZ Ultraleggera 8x18 ET45/Brembo 328x28 2pcs 4 pot ''A'' caliper/Braille Battery
« Reply #2 on: July 29, 2010, 07:45:05 pm »
And are Cupra front hubs alloy???
Offline laurent.d
« Reply #3 on: July 29, 2010, 08:01:10 pm »
Good question!
« Reply #4 on: July 29, 2010, 11:00:36 pm »
This is where I get a bit confused (again!). Are you talking about S3 rear brakes (whole kit) being fitted to a GTI?
« Reply #5 on: July 30, 2010, 12:53:19 am »
No Robin, it is the hubs that the discs fit to :smiley:
Offline poko
« Reply #6 on: August 02, 2010, 02:28:42 pm »
Cupra Front HUBS are alloy and even have "AUDI" written all over them.
they are directly from an S3 and share the part number as well (they didn't even bother rebadging them as SEAT).
the rear hubs are standard metal GTI ones and the S3 ones DO NOT FIT.
the entire rear floorplan is different from the S3 to our cars due to the haldex.
if you would want to fit an haldex in a cupra / GTI you would need to cut the rear floor / fuel tank and replace them with the A3 variants.
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #7 on: August 02, 2010, 03:42:48 pm »
Simple.....Fit rocco rear bubs, alloy and no drive shafts......
Thankyou - no charge....
 :star: :star: :star: :star: :star:
  • -Given: 243
  • -Receive: 155
« Reply #8 on: August 02, 2010, 04:29:07 pm »
Now that's good thinking  :happy2:
Offline laurent.d
« Reply #9 on: August 02, 2010, 07:33:51 pm »
Thanks guys for your answers. :happy2:
Do you know if rear Scirocco hubs widen the track?
Because, golf Track (Front/rear) = 1533/1515
While Scirocco Track (Front/rear) = 1553/1561
Front is 20mm wider while rear is 46mm wider.
Any answer?
Offline fuscobal
« Reply #10 on: October 01, 2010, 06:48:36 am »
46mm is a lot. If the chassis is the same, then the widening must come from the hubs probably but the upper shell of the car is wider too. If widening our cars that much on the rear we will probably rub against the fenders/arches !
Mk5 GTI 6MT - Revo stage 3
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #11 on: October 03, 2010, 09:03:48 pm »
Presumably, these alloy hubs are to reduce unsprung weight?  Do they make a noticeable difference?
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #12 on: October 17, 2010, 01:32:24 am »
Nope, they are cast iron.
  • -Given: 88
  • -Receive: 95
« Reply #13 on: October 17, 2010, 01:36:24 am »
Are you sure?
The Rocco R uses cast iron front lower wishbones, and they look like they have cast iron hubs . . .
Put a Rocco R alongside an S3, and the bits look very different.
  • Trader - 2014
  • -Receive: 130
« Reply #14 on: November 03, 2010, 11:43:56 pm »
Hi Sean
My Rocco is a 140PD and has alloy rear hubs, steel fronts.
