Author Topic: Cooked KO4  (Read 8999 times)
Re: Cooked KO4
« Reply #15 on: August 03, 2010, 11:21:30 am »
but would the actuator not increase this boost if that was not set up correctly ?
Re: Cooked KO4
« Reply #16 on: August 03, 2010, 11:24:18 am »
it was revo before the forge actuator  :happy2:
i thought the actuator was a fitted a bit tight as I was logging and getting overboost when it was first fitted, so i reduced the boost via the sps switch and had plans to get it back in to be looked at but never got time as i was manic at work and then pranged it..
probably my own fault for not sorting it sooner  :stupid:
anyhow my next car is not going to have a turbo and no after market mods  :signLOL:
so the best thing to do if having the actuator fitted is get it set up correctly with plenty of logging done  :smiley:
Offline GTIjames
Re: Cooked KO4
« Reply #17 on: August 03, 2010, 11:39:21 am »
Yeah definitely not a simple bolt on mod like a exhaust or intake this requires some testing and logging  to be set up properly.
Not 100% sure if this is the cause but looks likely,
I know mine is not the first ko4 to be killed on here so any idea on what caused the others to go and any similar to mine.
Re: Cooked KO4
« Reply #18 on: August 03, 2010, 11:42:19 am »
all the ones i know of that had blown turbos had fuel pumps done  :confused:  infact i think they all ran revo stage 2 + too  :confused:
« Last Edit: August 03, 2010, 11:45:46 am by MAT ED30 »
Offline GTIjames
Re: Cooked KO4
« Reply #19 on: August 03, 2010, 11:44:51 am »
Mines been running apr fuel pump for 15k miles now and no problems on that side what so ever, cam follower is in good order too
Ps for sale soon, pm if interested
Offline Janner_Sy
  • -Receive: 113
Re: Cooked KO4
« Reply #20 on: August 03, 2010, 12:35:37 pm »
where would ythose shards of metal be then??  stuick up against the IC core or exiting via the exhaust. not to sure which turbine that is
Offline S2 Ant
  • -Receive: 21
Re: Cooked KO4
« Reply #21 on: August 03, 2010, 12:38:53 pm »
Looks like the hotside to me... exhaust.
Ant
Offline Bogwoppit
Re: Cooked KO4
« Reply #22 on: August 03, 2010, 12:52:43 pm »
Those shards of metal will be rattling around inside the cat somewhere.
Offline KRL
  • -Receive: 29
Re: Cooked KO4
« Reply #23 on: August 03, 2010, 12:56:26 pm »
Have JKM commented on whether they think the turbo was running too hot?  I am no expert but from the picks it looks to me like it might have been?
Running too hot could be caused by a couple of things - running too lean or running too much boost.
« Last Edit: August 03, 2010, 01:09:22 pm by KRL »
Offline PDT
  • -Receive: 142
Re: Cooked KO4
« Reply #24 on: August 03, 2010, 01:58:40 pm »
EGT'S were too high in all probability, have seen this on a few occasions with very similar damage as a result.
Offline gazbutS3
Re: Cooked KO4
« Reply #25 on: August 03, 2010, 02:10:47 pm »
I thought the fuel setting was a bit lean for running a pump :smiley:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: Cooked KO4
« Reply #26 on: August 03, 2010, 02:43:48 pm »
would have thought 28psi is taking you well into uncharted EGT territory on a sustained run  :surprised:
Red ED35 5dr DSG
BLOG | BUILD
Offline GTIjames
Re: Cooked KO4
« Reply #27 on: August 03, 2010, 02:55:49 pm »
It only ever spiked at 28psi then held at 24/25psi
Jkm suspected egts as a cause but will investigate further, although since I have had the car back from accident repairs it has not had an uprated intercooler on, however  I have not done that many miles, c2k.
I probably should have dropped the boost back further with the absence of a I/c but you live and learn, let it be a warning for those going stage 2+ to monitor everything to make sure it does not get too hot down there, luckily mine was saved by jkm before any serious damage was done to the engine or any other parts   :happy2:
Offline Janner_Sy
  • -Receive: 113
Re: Cooked KO4
« Reply #28 on: August 03, 2010, 04:04:48 pm »
since you need a new k04, you should get one and hybridize it :party: :party:
Offline JKM
  • Trader - 2014
  • JKM Performance
Re: Cooked KO4
« Reply #29 on: August 03, 2010, 04:07:23 pm »
Guys I have just seen this thread that our customer put up. This fault may have been caused by a number of issues, EGT is one of them and this is what we thought on first seeing the turbo - however to be totally confident of the cause it would need to be properly analysed by an actual turbo specialist such as a company who build them and have substantial real knowledge of failure modes.
EGT’s can be raised as a result of to much boost / running a lean AFR or even excessively retarded timing (as per Turbo Anti Lag systems!!). Taking one example from these listed - Lean running can be due to lots and lots of reasons on the TFSI engine and would need proper investigation on its own to pin point anything (even if this was the reason for the fault).
A brand new turbo has now been fitted to the customers car and the old unit has to be returned as a core unit, As the car is in our workshop to be returned to factory stock and looking at how much stuff has been taken off -  the fault (if it were a hardware issue) could easily get taken off during this process, the car is still in the workshop now having parts removed!!
We will certainly be checking the car over substantially before it leaves as this failure was only seen once work had got underway on it.
Something that is possibly related and you can see from the image I have attached below - is that this turbo is also leaking exhaust gases from the centre v-band clamp on the turbo housing itself. We have not seen this happen before on any TFSI turbo in our workshop either. Exhaust soot can be seen over a section of the turbo compressor housing.
We do know the rather unfortunate history of this car, and it did get a bit of a large shock load to the exhaust system not to long ago.
There is the possibility that the two events are actually related – large knock to the exhaust transferring a large axial load onto the turbo housing. If the turbo wheel was still spinning at the point of the large load (which I think it would have been) then turbo wheel damage ‘could’ have resulted, it could have been only one section/blade that took an unusual loading and then failed - that would lead to a foreign object being spun around causing more damage. It is just a wild theory but keeping in mind the shock load on the exhaust that would have been transferred we wouldn’t want to rule it out.
For the record JKM haven’t actually seen the need to use the Forge actuator from the testing that we have done, however we acknowledge that that nature of tuning cars will mean that customers will always like to try new products as they come to marketplace. I have not seen any logs from the car running on this actuator myself so I am sorry that I can’t comment further on how much the boost had been over spiking etc.
Above are some of the possibilities of what ‘may’ or may not have caused this failure. Please also note that JKM did not install/configure this cars Stage 2+ code before anyone asks.
One of our workshop Technicians spotted this the moment the turbo was off. The turbo shaft assembly would have been seriously out of balance and may have failed catastrophically if left!
I hope this helps with some extra input. Hopefully its not to confusing for you, my head hurts anyway!
Once the car is back to stock I will be giving it a good road test to see if anything looks wrong.
Keith
« Last Edit: August 03, 2010, 04:10:22 pm by JKM »
The Premier VAG Servicing, Diagnostic & DYNO DYNAMICS ROLLING ROAD Tuning Centre
VAG 2.0 TFSI Performance upgrade Specialists
REVO | Superchips & Bluefin software | Emerald K3 ECU Specialists
Visit the JKM website - www.jkm.org.uk
