Author Topic: RNS 510 tricky volume control  (Read 4173 times)
Offline WilliamOT
« on: September 01, 2010, 02:48:47 pm »
Hi there im new to this forum. I have just bough an 06 black gti. I new it would be a good car, but im stunned how good it really is. I have owned a few different sports cars in my time, but what a great car.
Anyway, my post, it has a rns510 b unit ( i think its a b) fitted. The volume control only works if you apply pressure on it. Does anyone know where or how i can get this fixed.
Sorry if this is in the wrong section of the forum.
Offline mortygttdi
  • -Receive: 146
Re: RNS 510 tricky volume control
« Reply #1 on: September 01, 2010, 05:35:28 pm »
Hi William can you let me know what its specifically doing..?  I fixed one the other day for Winrya hopefully its still going strong?
Darren
Offline WilliamOT
« Reply #2 on: September 01, 2010, 06:42:57 pm »
hi Darren, the volume button just spins around without changing the volume. To make it work you have to apply pressure in a down direction and then turn it. It then works. Its not the end of the world, its just abit of a pain. Also when driving and you go over a bump the volume bar shows up on the screen. ?? What do you think. ALSO it only seems to pick up 2 or 3 satalites on the nav??. It was a retro fit system.
Will.
Offline 182_blue
  • -Receive: 54
« Reply #3 on: September 01, 2010, 06:46:05 pm »
Will.
looks like there is an issue with the button, Morty might be able to sort it, might mean taking it to bits of course  :laugh:, as for the satelites can you see the GPS antenna ?, or is it hidden in the dash somewhere ?, if its hidden moving it somewhere else with less things in front of it should improve the signal
Offline mortygttdi
  • -Receive: 146
« Reply #4 on: September 01, 2010, 11:33:39 pm »
i can at least look at it for you ill try soldering the connections and see if this sorts it? I would presume its just a dry board or a crack in the solder which is why when you push on it it works.
Where abouts are you?
Darren
Offline WilliamOT
« Reply #5 on: September 02, 2010, 09:05:45 am »
Hi Darren, Im in Nottingham. Could you e mail me your contact details and i will give you a call
Will.
Offline winrya
« Reply #6 on: September 02, 2010, 10:32:43 am »
Darren
Yes Darren, still going strong thanks mate.
Funny, I've searched for 9 months to see if anyone else has ever had this issue, a day after mine is fixed, someone pops up  :laugh:
Same symptoms as me, i had to hold mine to the left for it to work but by the end there was almost no control.  I'm sure Darrens soldering fix will do the trick.
Ryan
« Last Edit: September 02, 2010, 10:34:36 am by winrya »
Offline WilliamOT
« Reply #7 on: September 02, 2010, 06:49:36 pm »
thanks for all the help, I will try and have a chat with Darren tomorrow.
Will
Offline WilliamOT
« Reply #8 on: September 05, 2010, 03:20:12 pm »
Darren, when can we have a chat so i can bring the car and unit to you?
Will.
Offline mortygttdi
  • -Receive: 146
« Reply #9 on: September 05, 2010, 06:06:26 pm »
Ill give you a call tomorrow mate and sort it out with you :happy2:
Darren
Offline WilliamOT
« Reply #10 on: September 05, 2010, 08:03:47 pm »
thanks you are a star :drinking:
Offline WilliamOT
« Reply #11 on: October 16, 2010, 03:14:27 pm »
Thanks Darren, its working great.
Thanks for you time today
Will.
Offline mortygttdi
  • -Receive: 146
« Reply #12 on: October 16, 2010, 04:54:08 pm »
No problems Will glad I could help mate :happy2:
Darren
Offline Poppa Dom
« Reply #13 on: October 16, 2010, 07:56:52 pm »
Nkomo, having a similar issue with mine, though it is the right hand rotary switch.
Offline mortygttdi
  • -Receive: 146
« Reply #14 on: October 16, 2010, 11:06:07 pm »
Seems to be cropping up a bit more then,  then again 3rd time in 1 forum :confused:
Darren
