Author Topic: Hella Daytime Running Light LED's....  (Read 135283 times)
Offline Snoopy
  • -Given: 31
Re: Daytime Running Light LED's....
« Reply #120 on: November 12, 2010, 09:15:46 pm »
Robin,
I think the new fabia vRS has the same DRL as yours  :smiley:
I have not seen one on the road but the foglight area the light looks like a cluster of LEDs like yours  :happy2:
« Reply #121 on: November 12, 2010, 10:30:38 pm »
Robin,
....Interesting  :happy2:
This illustration clearly shows a 4-bulb LED DRL unit in the usual foglight position like mine. There's folks on Briskoda (I'm not registered there) wanting to retro fit these DRL's.
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #122 on: November 13, 2010, 11:39:33 am »
Yep there are as ive given people the part no in the past :laugh:
They are £65ish quid each iirc
You can get the same thing for an Octavia Scout and I'm pretty sure it would fit the Octavia vRS as it "looks" to be an identical housing (the scout one not the Fabia).
Offline animal
  • .:R32
« Reply #123 on: November 15, 2010, 04:01:10 pm »
The Octavia has strips though doesnt it (which I think are Philips OEM)?
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #124 on: November 15, 2010, 04:59:59 pm »
Yes the Octavia does but there is an option for foglight style ones on the Octavia Scout (Skoda equiv of the Audi All-Road)
The Pre-Face Lift vRS doesn't have DRL.
Offline animal
  • .:R32
« Reply #125 on: November 17, 2010, 01:49:20 pm »
Carl, how much are the vRS strips?
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #126 on: November 17, 2010, 02:51:12 pm »
The OEM ones are approximate £150 Each. Part No.s are (1 left and 1 right)
1Z0 941 067
1Z0 941 068
You can get ones like I have installed though for £35 from here
Click Moi
This is what they look like fitted & working (ignore the holes they were from a previous test)
« Last Edit: November 17, 2010, 03:02:34 pm by vRS Carl »
Offline animal
  • .:R32
« Reply #127 on: November 18, 2010, 12:19:50 pm »
Thanks Carl, and looking good. I've been looking at the Philips kit myself but would like to keep things OEM if possible.
As I have an R32, the slatted from grills lend themselves to the strips rather than the fog light/spots. However, I'm not a fan of the S6 units as I think they are just too much. And it's already been done several times over.
Do you have access to the dimensions of the vRS units?
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #128 on: November 18, 2010, 01:23:47 pm »
I don't mate sorry and ETKA doesn't list the size of each unit either  :sad1:
« Reply #129 on: November 18, 2010, 06:23:15 pm »
....In my web surfing travels when I was researching how to do mine, I came across S6 units on Mk5 R32's and a How-To (in German IIRC) which had lots of pics and showed cutting of metalwork. In other words not too straightforward. I don't have a link anymore.
Offline apollo13
  • -Receive: 47
« Reply #130 on: November 19, 2010, 10:43:47 am »
1Z0 941 067
1Z0 941 068
Click Moi
Carl would I be right in saying the ones you have don't dim when the headlights come on?? Iv been toying with the idea of these in my GT fog grilles. How do you think they would fit?
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #131 on: November 19, 2010, 02:13:28 pm »
Yes mate you can make them dim when the headlights come on. I haven't but Dave (Muckipup) has done it with his. :happy2:
Offline apollo13
  • -Receive: 47
« Reply #132 on: November 19, 2010, 02:30:20 pm »
Sorry about that dodgy post! The reply box goes weird on my phone! Ah so you can get them to dim, Ill have to consider these then. Cheers Carl   :drinking:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #133 on: November 19, 2010, 02:45:00 pm »
You get supplied 3 wires. Red, Black & Yellow. The Yellow wire determines wether they dim or not.
This is what Dave did to achieve it.
Quick update - the advice I gave regarding connecting the yellow DRL wire to the yellow/black on the car was based on the car with ignition on / engine off.
I fitted the DRLs today and wired them as mentioned previously and noticed that having the engine running gave a slightly different result.  The next six pics are:
1. Ignition on / engine off / no lights
2. Ignition on / engine off / side lights
3. Ignition on / engine off / main lights
4. Engine on / no lights
5. Engine on / side lights
6. Engine on / main lights
Spot the difference between 3 and 6....with the engine running, when switching on the main beam, the DRL goes dim instead of going completely off.  Not sure if I prefer this or not.  I may get the multimeter out and test things again but with the engine running this time  :ashamed: However, I'd be interested to hear opinions - DRLs dimmed with main beam or off???
1.
2.
3.
4.
5.
6.
« Reply #134 on: November 19, 2010, 05:23:56 pm »
Damn! I'm liking the style of strip DRL's plus fogs more and more but can't justify the expense of changing mine.
