Author Topic: rich83 - Edition 30..... Breaking  (Read 758573 times)
Offline xjay1337
  • -Receive: 377
Re: rich83 - Edition 30 Cam Chain Done!
« Reply #2385 on: May 16, 2016, 09:16:46 am »
Rich remember I sent you a chart of brake fluid wet and fresh boiling points...use that...I think it was Motul 300v....?
Don't forget your wind up tool.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=n0pb8dcsji05ort4glfkcvv4ii&/topic,19740.0.html
« Reply #2386 on: May 16, 2016, 01:18:02 pm »
Just went for OEM In the end jay....  300v is oil  :signLOL:
« Last Edit: May 16, 2016, 01:24:52 pm by rich83 »
Offline Beej
« Reply #2387 on: May 16, 2016, 01:50:40 pm »
Picked up some things for my rear brake refresh. Just need some pads and fluid.
Is that the genuine vw triple square m14 bit you have there??
« Reply #2388 on: May 16, 2016, 02:00:24 pm »
Yes it is.  :happy2:
Offline Beej
« Reply #2389 on: May 16, 2016, 05:27:52 pm »
I done mine at the weekend, but the drivers side needs to come back off again for me to swap out the dud caliper, does the vw tool make it easier than using my sort of large and deep triple square?
« Reply #2390 on: May 17, 2016, 07:22:02 pm »
No idea.  :signLOL:
Rear disc barrels painted in high temp paint.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #2391 on: May 17, 2016, 07:43:47 pm »
They look very nice! :happy2:
dansmith180
« Reply #2392 on: May 17, 2016, 08:11:07 pm »
Always a nice touch to stop them going bloddy orange. You should do the face of the disc as well so it matches  :happy2:
« Reply #2393 on: May 17, 2016, 09:01:26 pm »
 :signLOL:
Offline xjay1337
  • -Receive: 377
« Reply #2394 on: May 18, 2016, 08:40:33 pm »
Cheap bugger not buying discs black already..  :pomppomp:
« Reply #2395 on: May 18, 2016, 09:00:22 pm »
Discs were cheeeeeeeap mate  :happy2:
Re: rich83 - Edition 30 Rear Brakes
« Reply #2396 on: May 20, 2016, 12:22:56 pm »
A bit of progress.
Pads were f*cked.... not good. Brembo HP Sport
Not much room to get the wrench in (yes I know you shouldnt use a torque wrench to undo bolts)
Just go the change the brake fluid and bleed them properly.
« Reply #2397 on: May 20, 2016, 12:24:58 pm »
I intended to buy some new calipers and carriers soon and change them over as these are very very tatty.
« Reply #2398 on: May 20, 2016, 03:26:00 pm »
Fluid out of the reservoir
Went for a little drive. The brake pedal does seem a bit firmer than before, which has given them a nicer "bite"
Pads sweep the entire surface of the 282mm discs, so no lip will form.
Happy!  :jumpmove:
Offline doylebros
« Reply #2399 on: May 20, 2016, 07:53:04 pm »
That fluid is very dark for a vehicle which gets such TLC Rich, how long since its been changed and are you removing the pre filter on the reservoir?
You never said how you found your new pressure bleeder?
