Author Topic: rich83 - Edition 30..... Breaking  (Read 751963 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: rich83 - Edition 30..... 12 Years
« Reply #2550 on: April 14, 2022, 08:16:09 pm »
It's not a fun job to do indeed! Give us feedback if that sorted the heat soaking issue.  :happy2:
  • -Receive: 690
« Reply #2551 on: April 15, 2022, 12:01:27 pm »
Good stuff.  WOO indeed  :happy2:  Good work on the seat repair.  I need to replace my lumbar support mechanism and the back rest heating element....but erm...yeah, you can only get the heating element as part of the entire upper seat cover, at £850.  Cheers for that VW  :happy2:
« Reply #2552 on: April 15, 2022, 11:03:30 pm »
Thanks chaps. Seem like it's blowing nice and cold when I took it out today.
That's a sh*tter about the heater element I presumed the seat covers for the ed30 would be obsolete now. Can you not harvest one from a different seat?
  • -Receive: 690
« Reply #2553 on: April 17, 2022, 11:49:00 am »
Yeah still available, probably dry rotting in a warehouse somewhere because they would rather throw them away than sell them off cheaper.
I've replaced the covers on MK4 R32 seats before what a ball ache that job is!  A passenger seat from Europe might be the best option.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #2554 on: April 18, 2022, 01:11:41 am »
You can retrieve the parts from another mk5 Golf electric and heated seat and swap them to your seat. It'll be much cheaper.
Offline RBS
  • -Receive: 47
« Reply #2555 on: April 18, 2022, 09:36:55 pm »
Yeah! Like Shoduchi mentioned, get them second hand and swap it over :happy2:
« Reply #2556 on: May 18, 2022, 08:24:44 pm »
All this talk about cam followers and camshaft lobe wear was starting to make me nervous. I had checked this 1000 miles ago and though for the sake of £50 I would throw on a new one. I think this is probably follower number 3 on this engine.
« Last Edit: May 18, 2022, 08:27:58 pm by rich83 »
  • -Receive: 690
« Reply #2557 on: May 19, 2022, 12:50:03 pm »
If I’ve read that right, that’s a lot of wear for 1000 miles. Normal wear pattern though, so the cam lobe is fine. Uprated fuel pump?
« Reply #2558 on: May 19, 2022, 12:54:00 pm »
Sorry. I meant I had checked it 1000 miles ago and decided it could do with a change. It's probably got 50-70k on it, last changed 2015. Oem pump
« Last Edit: May 19, 2022, 12:55:35 pm by rich83 »
  • -Receive: 690
« Reply #2559 on: May 19, 2022, 03:14:14 pm »
In that case, all looking good there  :happy2:
« Reply #2560 on: May 25, 2022, 11:57:39 pm »
Current filter in over 100,000miles old so this one will be put on over the weekend hopefully.
OEM filter £33.20.
« Reply #2561 on: May 27, 2022, 03:26:29 pm »
Not too bad a job. Luckily the screw was ok but it really needs a new on as it's head is corroded.  Lots of black crap inside.
« Reply #2562 on: May 28, 2022, 03:04:07 pm »
Well that wasn't fun. Spark plugs. No4 was rusty on top and pig to get out. No2 was also very difficult to remove, felt like the thread was spinning.
I think I'll change plugs every service from now on.
Also these plugs used to be made in Japan but they are now made in Thailand. Just FYI.
« Last Edit: May 28, 2022, 03:07:12 pm by rich83 »
Offline JoshB
« Reply #2563 on: May 30, 2022, 06:32:52 am »
Good job on the fuel filter, mine was a complete pain… my pipes wouldn’t budge!
Spark plugs should not get rusty… water shouldn’t be getting anywhere near there…!
Check your seals on your coils.
Getting too old for this...
« Reply #2564 on: May 30, 2022, 11:24:20 am »
I agree.  I might swap the coil packs for new r8 ones soon, although the seals looked fine.
