Author Topic: Gti open mouth grills for ed 30  (Read 24880 times)
Offline Toast
« on: February 07, 2009, 06:59:46 pm »
Looking for some info on these as the solid grills around the fogs look mince :sick: And If I'm planing on goin bigger brakes thought they'd help with the cooling!  Can these be bought from the dealer and if so what price?
And info would be appreciated  :happy2:
Toast
Re: Gti open mouth grills for ed 30
« Reply #1 on: February 07, 2009, 07:15:40 pm »
They wont help much with brake cooling unless you add ducts from them right through the wheel arches.
There is a certain amount of air circulation from the 'open grills' but the driver's side is mostly blocked off behind.
Someone on this forum has ducted it all properly and hopefully will post here.
Open fog grills are easily available from Fischer in Germany and not at all expensive - £30-ish?
HTH :happy2:
Offline bacillus
  • -Receive: 453
« Reply #3 on: February 07, 2009, 07:29:44 pm »
Cheaper to get them from your local dealer but don't tell TT!  :chicken:
iirc, someone posted the part numbers on the golfgti forum a while back
Offline Toast
« Reply #4 on: February 07, 2009, 07:32:17 pm »
Thanks for the info guys :happy2:
I wondered if vw did them!
Toast
Offline 182_blue
  • -Receive: 54
« Reply #5 on: February 07, 2009, 07:33:17 pm »
i didnt know VW did them either
Offline fastismycopilot
« Reply #6 on: February 07, 2009, 07:39:18 pm »
I've got a pair of them sitting in the garage........ been waiting to get around to fitting them for a year or so now. Should get on with it, I know.  :ashamed:
Edition 30 No. 0536
Offline Toast
« Reply #7 on: February 07, 2009, 07:42:38 pm »
A quick 5 minute Job Buddy :happy2:
Toast
« Reply #8 on: February 07, 2009, 07:53:51 pm »
I'd go for these at the same time as uprated brakes. Then I could duct the brakes.
« Reply #9 on: February 07, 2009, 07:58:57 pm »
Or you could neatly cut a round hole in each stock (closed) grill - Might look very cool.
Most of the VW Cup race cars use the foglight aperture to run ducts from.
You'll probably need some kind of mesh/screen to stop leaves etc getting into the ducts.
« Last Edit: February 08, 2009, 12:11:09 am by RedRobin »
Offline WhiteGTI
  • F-A-S-T
« Reply #10 on: February 07, 2009, 08:03:01 pm »
Can get them from here: http://www.vwspeed.co.uk/volkswagen/vw-parts/Mk5_Golf_GT_GTI_Cooling_Grilles-2295-234.html
Delivered mine the next day!
But I hear that they are slightly cheaper from a dealer.
2006 E46 BMW M3 - 343hp
Offline Shaun
« Reply #11 on: February 07, 2009, 08:37:22 pm »
Robin... there appears to be some 'ducting' behind yours in the picture taken (presumably) when you were fitting your DLRs, but this doesn't look as if it comes with either of the versions of the open grilles to which links have been given. Do I have to obtain this separately? I like the idea of the open grilles but worry about the untidy mess that would appear behind them if they're just large holes?!
Thanks,
Shaun
Keep The Faith
GTI Edition 30 No. 0687 - Candy White - 5 Door - Lux Pack 1 - Park Sensors - ITG Filter - Bluefin - ECD Insert - Cruise Control
Previously: Mk1 Golf - Mk1 Jetta - Mk1 Polo Coupe - Mk2 Jetta - Mk3 Golf - Mk4 Passat - Mk1 Polo - Bora - Audi A4 / A6 / A8 - Mk3 Polo - Mk4 Golf
Offline bacillus
  • -Receive: 453
« Reply #12 on: February 07, 2009, 08:55:17 pm »
The ones from vwspeed look like they don't come with the rear inserts!
The ones from fischermotor sport come with inserts; on the driver side it completely blocks the rear of the grill and on the passenger side you get a duct like insert that directs air to to behind the grill.
« Reply #13 on: February 07, 2009, 09:01:44 pm »
Shaun - It's as bacillus says.
I didn't know until now that anyone supplied them without the rear 'inserts'!
Having seen Neil's at Santa Pod, I'm thinking of changing mine to carbonfibre ones :evilgrin:
Offline Shaun
« Reply #14 on: February 07, 2009, 09:02:22 pm »
Thanks, bacillus... anyone know if the ones from the dealers come with these (I'm dubious as they're apparently cheaper!)?
Keep The Faith
