Author Topic: URGENT HELP NEEDED - Bonnet wont close  (Read 37747 times)
Offline Rob GTI
« on: October 03, 2010, 08:38:11 pm »
Just checked the oil and the bonnet won't slam shut. (it rests like it was just popped from inside).
The dealer changed the pull mech under warranty last year and it has been really tight to open and a lot of play in the release since then.
Anayway I've got a flight to catch in the morning so need to know how to properly shut the bonnet until I get back.
Any ideas?
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Re: URGENT HELP NEEDED - Bonnet wont close
« Reply #1 on: October 03, 2010, 09:10:04 pm »
Wd40 in the bonnet mechanism?
Offline v2brett
« Reply #2 on: October 03, 2010, 09:31:17 pm »
as above and try pulling the bonnet release handle again
Still Here!
« Reply #3 on: October 03, 2010, 09:38:14 pm »
Check that the pull handle inside the car is pushed back into the rest position.
Offline G4V VW
« Reply #4 on: October 03, 2010, 09:48:58 pm »
Mine started like that and after a few goes pulling the bonnet lever it used to shut....until that is it stopped and i got angry and ending up pulling the bonnet lever to hard and snapped the lever. Changed the lever and bonnet mechanism in the end and now smooth and easy to open and shut  :smiley:
Offline Rob GTI
« Reply #5 on: October 03, 2010, 09:56:35 pm »
Thanks for thetips guys, tried them all, but no joy, starting to think that they neveer changed it at all.
Leaving the WD soak then try again in an hour.
  • -Given: 380
  • -Receive: 442
« Reply #6 on: October 03, 2010, 10:19:00 pm »
I've had that exact problem. I reckon you'll find that the spring mechanism in the unit mounted in the slam panel is at fault. It's actually a known issue on Mk5's and the only longterm solution is to replace the whole lock unit. Meanwhile you'll have to fiddle with a screwdriver or similar to 'spring' it. So check all your fluids, close the bonnet, and don't open it again until at your dealer with a replacement part.
A worse version of this problem is if you can't open the bonnet.
Offline Drapoon
« Reply #7 on: October 03, 2010, 10:26:39 pm »
I struggle to open my bonnet, tried soaking mechanism in duck oil but no joy
Was v embarrassing when I used the lifts at my dads work to change the oil :ashamed:
I though it might be due to my ocd jetwashing habits drying out the spring :signLOL:
Offline mortygttdi
  • -Receive: 146
« Reply #8 on: October 03, 2010, 10:47:28 pm »
there is 3 bolt/screws holding the bonnet mech in loosen them spray loads of wd in and shut the bonnet until you get back home you can sort it out when you get back.
Darren :happy2:
Offline Rob GTI
« Reply #9 on: October 03, 2010, 11:18:43 pm »
Darren :happy2:
All I can see on the slam panel are 3 screws either side by the headlights. Where abouts are the 3 you mean?
« Reply #10 on: October 03, 2010, 11:28:48 pm »
here is a pic of mine 54 plate gttdi..not sure if its the same as yours thou..you can see the bolts Darren is on about
« Last Edit: October 03, 2010, 11:31:12 pm by maxitrol »
Offline Rob GTI
« Reply #11 on: October 03, 2010, 11:31:12 pm »
Ah so its grill off?
Need to find a quick how to on that?
Offline mortygttdi
  • -Receive: 146
« Reply #12 on: October 03, 2010, 11:35:10 pm »
The grill
2 hex screws on top and 2 under the reg plate you will see them if you get on your knees and peep up under the reg.
Darren
  • -Given: 380
  • -Receive: 442
« Reply #13 on: October 03, 2010, 11:39:13 pm »
Hurdy managed to fiddle about with mine with a screwdriver without removing any grills etc. We were at the Nurburgring at the start of a private trackday, so mighty inconvenient and expensive if we hadn't sorted it.
« Reply #14 on: October 03, 2010, 11:39:49 pm »
thier was a topic on this i think
http://www.mk5golfgti.co.uk/forum/index.php/topic,6684.0.html
oops Daz beat me to it
