Author Topic: DRLs - anyone tried these? ** now with pics on pg10 **  (Read 121026 times)
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
Re: DRLs - anyone tried these? ** now with pics on pg10 **
« Reply #165 on: November 16, 2010, 08:09:05 pm »
I have managed to arrange a groupbuy with discount for all. Further details coming soon but it should be a chunk less than the £140 advertised price.
I am happy to organise it but need a number of people who are firmly interested. The more people who are interested the bigger the discount. As soon as I have the numbers I can confirm the discount.
If you copy and paste the below.
I'll start by adding my name:
1. Bodger00
2.
3.
4.
5.
6.
« Last Edit: November 21, 2010, 11:24:50 am by bodger00 »
Offline bindinbear
  • Newbie lovin' the edition 30
« Reply #166 on: November 16, 2010, 09:10:13 pm »
Interested mate provided I can use my flexible friend, upon confirmation of discount. Thanks
08' Edition 30 no.1899. 5dr steel grey DSG. MFSW, xenons, sunroof, rns510, ipod prep, armrest, voice activation, bluetooth, parking sensors.
Offline bindinbear
« Reply #167 on: November 16, 2010, 09:34:27 pm »
Do you think it's possible to put them on bullet connectors so they can be disconnected temporarily? They look super cool but come service or repair time( and I plan to extend the warranty when she's three) was thinking if they could be temp swapped then vw wouldn't be so bothered. I imagine on sight of these and tapping into the wiring will void any warranty? I might ask if vw want to fit em and they could do them as a vw endorsed retrofit!  :signLOL:
Offline bodger00
  • -Receive: 20
« Reply #168 on: November 16, 2010, 09:47:59 pm »
They already have connectors which can be unplugged if required. Payment will be by paypal directly to the supplier but with the group discount so via card would be the way.
So far we have:
1. Bodger00
2.Bindinbear
3.
4.
5.
6.
Please copy and paste the above adding your name if interested
« Last Edit: November 17, 2010, 06:17:40 pm by bodger00 »
Offline bodger00
  • -Receive: 20
« Reply #169 on: November 18, 2010, 09:27:57 pm »
Hi all, Les at Veedubmachine has come back to me and said that he will offer the drls at £122 each giving a saving of nearly twenty quid off! :happy2: :happy2:
All I need now is a list of people :rolleye: :rolleye:
A discount code will be given once I have a full list but be quick :wink: :wink:
« Reply #170 on: November 18, 2010, 10:07:56 pm »
1. Bodger00
2. Bindinbear
3. Stealthwolf
4.
5.
6.
Offline bodger00
  • -Receive: 20
« Reply #171 on: November 19, 2010, 06:03:28 pm »
He has also said he might "throw some other bits in too" whatever that means.
Offline bodger00
  • -Receive: 20
« Reply #172 on: November 21, 2010, 11:26:13 am »
Discount code promised by the end of today and will be live for a short period only. I will PM the code details as soon as I get them to those interested.
 :party: :party: :party:
Offline bodger00
  • -Receive: 20
« Reply #173 on: November 21, 2010, 09:18:53 pm »
Discount code is now live until the 5th of December for both the clear and the smoked lenses. Also on offer is a bonnet bra for those who are interested.
Full group buy info code here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,21797.msg294951.html#msg294951
Enjoy
Offline PND
  • -Receive: 62
« Reply #174 on: November 25, 2010, 08:14:35 pm »
Just in case anyone was wondering... mine passed its MOT today at a VW main dealer with the DRLs causing no problem at all!  :happy2:
  • -Given: 380
  • -Receive: 442
« Reply #175 on: November 25, 2010, 09:32:58 pm »
....That's good news  :happy2:
Offline bodger00
  • -Receive: 20
« Reply #176 on: November 26, 2010, 07:48:29 pm »
I received mine today and can vouch for the quality of the item :happy2:
Pity I cant say the same about the instructions....they are crap :ashamed: but thank god for this forum :happy2:
Offline PND
  • -Receive: 62
« Reply #177 on: November 26, 2010, 07:54:10 pm »
If you have any questions, ask away!  I'll try and answer if I can!  :happy2:
Offline bodger00
  • -Receive: 20
« Reply #178 on: November 26, 2010, 09:37:50 pm »
Thanks Paul. To be honest I am now trying to make sense of it all. I am technically minded and capable with a soldering iron so should not be impossible for me. Although I wish a had a Morty nearby :laugh:
After reading your instructional post I have two questions:
Where do you place the control units and how did you afix them?
and
After running the wire through the bulkhead how did you connect it to the spare fuse in the fuse box?
Presumably you used some sort of protective covering for the wires as they look like they could easilly get damaged in their current form?
Offline PND
  • -Receive: 62
« Reply #179 on: November 26, 2010, 10:25:44 pm »
Quote
black wire      : connect to ground (ended up fastening to chassis ground (blue nut in right of next picture)
white wire      : trigger to 'dim' - connect to pin10 on back of headlight connector (circled in next picture)
red wire        : connect to switched live (12v ignition) - connected to spare switched live in fusebox in dash
Darren ended up making it into a single loom by simply fastening the two reds, two whites, and two blacks together.  The reds were then extended with a single wire to go through the bulkhead behind the battery, ending up through the dash to the fusebox.  So, one connection at fusebox, one ground connection and one connection to pin10 on headlight connector.  The two dimming units were then passed down behind the nearside headlight, down behind the foglight.  The nearside dimmer module and connector were then ready to plug in to the nearside fog/DRL light unit.  The offside dimmer module and connector were passed behind the front grill/numberplate to the offside foglight area, ready for plugging in.
Additional info:
The 'trigger' feed was taken from pin10 off the back of the nearside headlight connector as shown above.  The black plastic surround was removed and the wire to pin10 was cut to allow the white 'trigger' wires to be connected.  Rather than using the supplied conectors, the wires were soldered and sealed using heatshrink.
Quote
The wiring and both of the control units were fed down behind the nearside headlight and the first module was positioned behind the nearside foglight grill, fastened to existing cabling with plastic cable ties, ready to connect the nearside DRL.  The sticky pads probably wouldn't have lasted very long.  The other module was fed behind the front grill/numberplate to the matching place behind the offside foglight grill.  Darren removed the front numberplate and grill to make this easier.  This second module was again cable-tied to the foglight wiring to hold it in place behind the grill.  The two fuses for each side were positioned next to the control module for that side to make access to them simpler.
Quote
This involved feeding the wire through the bulkhead from behind the battery into the dashboard below the glovebox area, behind the ashtray area and then up towards the fusebox.  Darren did remove the sides of the centre console to make this easier.  The connection to the fusebox involved adding a repair wire into the back of the fusebox into one the spare positions.  I think it was fuse position 41 that is used ideally.  I think we ended up using either position 40 or 43 from memory with a 15A fuse (Darren - can you confirm?)
This is an in-depth way of doing it (obviously left-hand drive)!  Darren managed to get a new connection in the back of the fusebox without removing any trim (apart from the fusebox cover and the storage drawer below the headlight switch).  He also managed it without having to take all the fuses out or sliding the release mechanism (sorry Darren if this wasn't the case!)  The fusebox can just about be squeezed out once its back cover has been removed, so the new wire can be inserted.
Addition of extra circuits to the Volkswagen Golf
Quote
Where the soldered joints were, Darren used heat-shrink and/or tape to cover the wires.  For the main loom, he just taped the wires together every few inches.
I hope that this is of some more help to you.  Apologies to Darren if anything is wrong in the above.. Please feel free to correct me!
Please ask again about which bits need more detail.  Anything more technical, I shall leave to Darren to explain!
All the best!
