Author Topic: Help epc light on and no power  (Read 26315 times)
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: Help epc light on and no power
« Reply #30 on: November 01, 2010, 05:01:37 pm »
With regards to the oil cap, I had to replace one because the 'handle' part at the top if you will split from the bottom part which effects the seal.  It wasn't leaking or letting air in or anything just very difficult to take off becuase you had to push down hard to make the thing turn.  Is this what the OP means rather than the sealing part has failed?
well the only thing that ive noticed weird under the bonnet is the oil cap has split in two again 3rd cap now is it possible the top half could have came off and hit summit and caused a fault
yeh the top part keeps coming off but the actual cap itself is still in the hole lol i need pliers to get it out
I think he's been misinterpreted here ...
Sepang Blue S4 BE Avant
Offline stu_no_1
« Reply #31 on: November 01, 2010, 05:05:04 pm »
yeh thats right the thing is still sealed its just the plastic handle thats came off i dont think ill bother with getting another one as they keep breaking
Offline stu_no_1
« Reply #32 on: November 01, 2010, 05:41:02 pm »
anybody know what this fault code means p2294 i cant seem to find anything other than fuel pressure sensor open circuit or bad connection
Offline PDT
  • -Receive: 142
« Reply #33 on: November 01, 2010, 06:12:06 pm »
Sure its not p2293?
http://wiki.ross-tech.com/wiki/index.php/18725/P2293/008851
I have seen this a couple of times, both times was fuel pressure sensor at fault.
Offline boxxer1973
« Reply #34 on: November 02, 2010, 01:27:28 pm »
my filler cap has done the same top part has gone all together now anybody know if the R8 oil cap fits ?
Mk5 golf Gti REVO. stg2+
Milltek | Auto tech | White line | Forge | REVO | KW | Quaife | helix clutch |
« Reply #35 on: November 02, 2010, 01:32:02 pm »
Boxer... yes the R8 cap fits!
Offline stu_no_1
« Reply #36 on: November 02, 2010, 04:43:17 pm »
the problem is the sensor on top of the fuel pump has cracked because of the engine cover hitting it because the mounts are broken the pump has to be replaced as a unit to fix this  i took a pic on my phone of the damage so the picture is not very good
so anybody with a loose engine cover dont just ignore it or it could cast you a fortune now im having to buy a new engine cover and a new fuel pump to fix the problem and ill be getting a new oil cap when i get the new cover on so if you have had problems with your oil caps breaking check that you engine cover is not hitting off your fuel pump
« Last Edit: November 02, 2010, 04:45:41 pm by stu_no_1 »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #37 on: November 02, 2010, 04:57:53 pm »
There is an APR pump on VAGOC IIRC.
Stu...
Offline stu_no_1
« Reply #38 on: November 02, 2010, 05:06:40 pm »
if only i didnt need to get it serviced asap after all this i would be wanting to get a hpfp its already pissing me off that i have to buy a new engine cover when i intend on getting a forge twintake at some point but i cant afford 350 plus a fuel pump and servicing it
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #39 on: November 02, 2010, 05:08:04 pm »
Can you borrow an engine cover from someone??
If not try the bay or a scrappy.
New cover is quite expensive as it includes a MAF.
Stu...
Offline stu_no_1
« Reply #40 on: November 02, 2010, 05:32:39 pm »
nobody i knows has an engine cover and was at my local scrappy the day nothing plus i dont know when ill have enough for an intake now anywayz so ive just ordered a new one costing me 150 it comes with a new air filter aswell
Offline boxxer1973
« Reply #41 on: November 02, 2010, 06:11:02 pm »
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #42 on: November 02, 2010, 06:30:27 pm »
If you buy an R8 cap from a dealer then you need to open it up to orientate the markings correctly - Quite simple though.
Some places such as awesome sell them already modified.
Stu...
Offline boxxer1973
« Reply #43 on: November 02, 2010, 08:10:58 pm »
Had to do it on my mk4 will get one from the steelers i think
Offline edd666999
  • -Receive: 89
« Reply #44 on: November 05, 2010, 01:48:14 pm »
Stu I have a engine cover + the sensor u require. Pm me if you didn't sort this.
