Author Topic: Help: Can't turn off rear wiper  (Read 26787 times)
Offline VWKD
    • VWKD
« on: November 13, 2010, 03:58:41 pm »
I just reversed out of a parking space and the rear wiper came on for no apparent reason and it won't turn off :( I tried putting rear wiper on and off, putting front and rear washers on, wipers on every speed and still it won't stop ...
Please help before I rip the darn thing off
Thanks in advance.
1971 T2 Camper
1972 Triumph Spitfire MkIV
1999 Passat TDI Running On Chip Fat
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
Re: Help: Can't turn off rear wiper
« Reply #1 on: November 13, 2010, 04:11:42 pm »
Does it come straight back on if you switch the engine off?. Could be faulty motor if so, so maybe remove fuse?.
Offline jeynesey
  • Mk5 GTi Edition 30
« Reply #2 on: November 13, 2010, 04:25:52 pm »
Is your boot open?
Offline VWKD
    • VWKD
« Reply #3 on: November 13, 2010, 07:08:36 pm »
Switched the engine off after a 45 min journey with the bloomin thing on and it has now gone off thank god. I haven't put it in reverse again since but suspect it will happen again next time I do.
Is it supposed to come on when you put the car in reverse ?
1971 T2 Camper
« Reply #4 on: November 13, 2010, 07:13:19 pm »
Do you have the auto wiper on? If it's on, then when you select reverse, will automatically wipe the rear view if the front wipers are activated by rain.
Shouldn't happen in the dry. Shouldn't happen (I think) if auto wipers are off.
There are reports of a faulty wiper motor causing havoc. May be worth searching the forum for the problem.
Offline mb
  • -Receive: 29
« Reply #5 on: November 13, 2010, 10:34:27 pm »
Thanks in advance.
Had this on mine where the wiper would just switch on whenever it wanted and the only way to stop it was to switch the ignition off.  VW changed the wiper motor under warranty.  Apparently it's a known fault.
Offline VWKD
    • VWKD
« Reply #6 on: November 13, 2010, 10:40:10 pm »
Excuse me for asking what is probably a very obvious question but I have only driven the car about 4 times.. how do you turn the auto wipers off. I'm sure they are on as when I have it in the intermittent position (first click up on the stalk) they come on and go off when they please and on the odd occasion they come on at the right time  :smiley:
1971 T2 Camper
Offline gti265
« Reply #7 on: November 14, 2010, 12:11:59 am »
just put it one click down, or as far down as possible i thing and thats of, one click up is auto, 2 clicks is constant and 3 is constant quick, i only use auto, and just use the sensitivity selecter to clear the windscreen if they are being slow :)
tom
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline VWKD
    • VWKD
« Reply #8 on: November 14, 2010, 11:09:46 am »
So is the little switch on the top of the wiper stalk for sensitivity rather than delay time like in the good old days?
1971 T2 Camper
« Reply #9 on: November 14, 2010, 11:14:03 am »
I think it depends on whether you have auto-wipers activated or not (I may be incorrect about this).
Offline VWKD
    • VWKD
« Reply #10 on: November 15, 2010, 04:47:36 pm »
Autowipers seem to work really well yesterday when it was actually raining... so at least I should be ok for most of the year  :smiley:
1971 T2 Camper
Offline jeynesey
« Reply #11 on: November 16, 2010, 12:34:17 pm »
Offline VWKD
    • VWKD
« Reply #12 on: November 16, 2010, 01:12:26 pm »
How does one activate them ? or de-activate would be preferable.
1971 T2 Camper
Offline mb
  • -Receive: 29
« Reply #13 on: November 16, 2010, 03:54:52 pm »
To activate the auto wipers push the stalk up to the first position (intermittant wipe).  The switch on the top varies how sensitive they are.
The only way to deactivate auto wipers, is not to use the intermittant setting.
« Last Edit: November 16, 2010, 03:58:15 pm by mb »
Offline VWKD
    • VWKD
« Reply #14 on: November 16, 2010, 05:12:00 pm »
How rubbish if only they stuck with the same intermitent set up they had on the Mk3 Golf/Corrado that set up rocked... I liked it so much that I'm installing the same relay on my old VW camper so it will have the same functionality... wonder if the relay will fit in the Mk5  :surprised:
1971 T2 Camper
