Author Topic: Macbook Pro running slow and HOT!  (Read 4070 times)
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« on: November 25, 2010, 09:07:43 pm »
Ok Guys,
I have had my Macbook Pro for 18 months now and recently it has been running slow with a fair amount of pinwheeling and at pretty much a constant 80c.
Spec
2.53 Ghz Core 2 Duo
4GB Ram
500GB Hard with over 100GB free
Running OS X 10.6.5
It has been a gradual deterioration and i would rather not do a system restore  but if needs be i will.
Any thoughts as to what could be causing this?
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Macbook Pro running slow and HOT!
« Reply #1 on: November 25, 2010, 09:21:40 pm »
Go into Apps >Utilities>Activity Monitor.
Look at the running processes and see what is using the CPU.
Also click on Settings>User Accounts>Login Items. See if there are any programs that are running at startup that you don't need.
Lastly download a program called Onyx (used to be free I think it still is) run that program before you go to bed and let it run overnight. Then just run that once every 3-4 months and it should be fine :happy2:
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #2 on: November 25, 2010, 09:33:43 pm »
Activity Monitor isn't showing anything obvious. Looks I'm about 15 pages into the Apple Support Discussions and i'm beginning to loose the will to live!
Offline Garth
    • My Build thread
« Reply #3 on: November 25, 2010, 10:19:25 pm »
Should have bought a windows laptop  :evilgrin:
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #4 on: November 25, 2010, 10:21:13 pm »
Lets not go down the Mac V Pc road as we know Mac's are far better  :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #5 on: November 25, 2010, 10:23:45 pm »
Did you get AppleCare when you bought it?
If so take it to an Apple Store and they will look at it for you.
I would try Onyx first though
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #6 on: November 25, 2010, 10:45:34 pm »
Sounds like you need to reset the PRAM
Offline Jules86
  • -Receive: 46
    • Forumwars
« Reply #7 on: November 25, 2010, 10:57:31 pm »
My girlfriends mac died because she used it on a pillow on her lap all the time. Does it have sufficient cooling allowance?
Offline bacillus
  • -Receive: 451
« Reply #8 on: November 25, 2010, 11:10:30 pm »
For a pc I would say that speed is being throttled because of cpu overheating.
A can of compressed air to clear out any accumulated debris on the cpu heatsink may be beneficial.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=pg9kt3iehbo0vuub0q4aqtb4kf&/topic,19740.0.html
« Reply #9 on: November 26, 2010, 11:45:48 pm »
Ant.... does it run the same on a guest account?
A new install with "archive and install" wouldnt hurt!
h4rdy
« Reply #10 on: November 27, 2010, 01:05:26 am »
Could be the HD failing.
That would make it slow as it would be trying to access data all the time.
Which in turn would make it hot as its constantly spinning and accessing.
As somebody else said try the Guest Account or set up another trial account.
If its still doing it I will put money on its the HD.
I have a Mac and PC and the PC one failed and this had the same symptoms.
Just put a 640gb HD into the Macbook Pro so if you need any advice just ask.
J
h4rdy
« Reply #11 on: November 27, 2010, 01:06:50 am »
And BACKUP everything NOW!
Do not put it off, if the HD fails thats it!
Offline cmdrfire
    • Commander Fire - my blog
« Reply #12 on: November 27, 2010, 01:57:23 pm »
Macs are PCs - they are personal computers. The hardware your Mac runs on is identical to the hardware on a nicely spec'd Windows machine. I think you mean "Mac V Windows".
And no, they're not.
/obvious troll is obvious?
//also, to be somewhat helpful and not make you entirely disgusted with me, similar issues on my mum's iMac resulted in eventual hdd failure. Back up everything NOW if you haven't already, and buy a replacement hdd to fit in there sooner rather than later. Avoid moving hundreds of files at once - this is what caused hers to eventually fall over. Recommend you back up files incrementally over a course of day in small batches, starting with the most important files first.
///Remember kids, HEAT results in hdd death. In a laptop resting on a duvet or a pillow or a cushion, the problem is magnified.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #13 on: November 27, 2010, 03:14:00 pm »
If you don't use it i highly recommend Time Machine for Backup's
Saved my bacon a few times :happy2:
« Reply #14 on: November 27, 2010, 10:48:00 pm »
Another vote for TC.... mines connected to a TM!
