Author Topic: grinding noise when loosing traction  (Read 2924 times)
Offline Russ_leeds
« on: November 28, 2010, 07:42:30 pm »
hi was on my way home earlier in the snow and when the car lost traction and the wheels began to spin there was a nasty grinding noise coming from  the left wheel. it does the noise both with the traction on and off.
any ideas?
cheers
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline tmagnet
Re: grinding noise when loosing traction
« Reply #1 on: November 28, 2010, 07:53:07 pm »
Probably the ABS cutting in, can't think of much else it could have been?
Offline markc
« Reply #2 on: November 28, 2010, 07:53:32 pm »
Mine made the same noise yesterday mate,  It spooked me too but I'm sure its nothing to worry about.
Had: Edition 30, 3 Door Manual, Pearl Black, Cruise Control, IPod Prep, Arm Rest, Auto Lights and Wipers
Offline winrya
« Reply #3 on: November 28, 2010, 08:02:41 pm »
You can't turn the traction control off completely. The noise I'm sure is the traction control applying the brake to stop the wheels spinning. In reality it just leaves you stuck:(
Offline QD MBE
  • -Receive: 102
« Reply #4 on: November 28, 2010, 08:05:17 pm »
X2 ESP cutting in
Offline Russ_leeds
« Reply #5 on: November 28, 2010, 08:06:33 pm »
ok cheers guys just wanted to make sure it was nothing to worry about :happy2:
Offline Eddy30
« Reply #6 on: November 28, 2010, 08:10:27 pm »
Ye think it's trac control mate,sounds horrible like your discs are scraping on the road!
Offline tmagnet
« Reply #7 on: November 28, 2010, 08:11:02 pm »
If you were really worried about it you could pull the ABS/ESP fuse(s) and see if the noise goes away, but I wouldn't recommend doing it for road use!
Offline 182_blue
  • -Receive: 54
« Reply #8 on: November 28, 2010, 08:34:16 pm »
Its quite normal, really spooked me the first time i heard it, really bad grinding noise
Offline Russ_leeds
« Reply #9 on: November 28, 2010, 11:35:56 pm »
cheers for all the replies :happy2:
Offline Eddy30
« Reply #10 on: December 02, 2010, 03:36:44 pm »
Does anyone know why it makes such a noise? Surely it's only the car applying the brakes?
Offline winrya
« Reply #11 on: December 02, 2010, 06:29:58 pm »
It is an awful noise and I'd also like to know the answer. Our mini copper s makes no noise when the traction control kicks in?
Offline markc
« Reply #12 on: December 02, 2010, 09:30:09 pm »
Founf this while looking around for an explanation on the 'grinding noise'
http://www.audiworld.com/tech/wheel6.shtml
« Reply #13 on: December 02, 2010, 09:34:55 pm »
Ahh. yeah... i guess its just the same grinding noise that you can hear when you brake and the ABS kicks in!
