Author Topic: Track driving technique  (Read 5985 times)
Offline keano
  • -Given: 79
« on: December 02, 2010, 08:30:54 pm »
Hi guys,
I was having a think ealier about how compitant i'd be on a track, come a track day etc...
How would you guys approach a hard right corner for example? With regards to braking and acceleration at what points etc.?
I've drawn a ridiculous picture in paint, as how i'd drive a rear wheel drive car ( I've done a few charity ferrari track day rubbish things under tuition)  - but does the same still apply to a fwd golf? And am i totally wrong?  :grin:
Any advice or pictures would be fun  :happy2:
Nick
Offline TrickGTI
Re: Track driving technique
« Reply #1 on: December 02, 2010, 08:34:53 pm »
haha brilliant effort on the pic i rekon that will take some beating  :happy2: but i rekon thats pretty much spot on obv depending on the corner depends on how much throttle half way round....
2006 Tornado red GTI
Offline keano
  • -Given: 79
« Reply #2 on: December 02, 2010, 08:36:07 pm »
haha! took me a good 3 minutes  :grin:
« Reply #3 on: December 02, 2010, 08:37:33 pm »
I'm not an expert but I would advise:
- Start slow and well within your comfort zone and gradually build your confidence and knowledge of the track.
- Always do your hard braking while the car is in a straight line and consequently more stable. Identify your braking point markers as you become more familiar with the circuit.
- Turn in towards the apex and start progressively applying power as soon as you can see the bend opening up.
- Basically 'slow in and fast out' is smoother and more stable.
- Do a cool down lap and never put your handbrake on when you park!
Be aware that many tracks may have a sequence of corners where you would be faster if you sacrifice the racing line on one corner to better get round the corner which immediately follows.
Never do another lap when you're thinking: "I'll just do one more lap" and always take a short break between sessions to keep yourself fresh.
Smoooothness is the key imo.
« Last Edit: December 02, 2010, 08:43:10 pm by RedRobin »
Offline TrickGTI
« Reply #4 on: December 02, 2010, 08:38:15 pm »
i sence a competion. me thinks entrys can only be done via paint  :popcornsoda:
Offline keano
  • -Given: 79
« Reply #5 on: December 02, 2010, 08:39:51 pm »
Cheers Robin.  :happy2:
I was hoping that you would visit this thread.
"Slow in, fast out" seems to be the key i guess. I vaugely remember it from past experiences.
Thank you!
« Reply #6 on: December 02, 2010, 08:47:52 pm »
Thank you!
....You're very welcome  :happy2:
As I say, I'm not an expert but I do have some experience. I've now added some more to my earlier post that I've remembered.
Tony_danza has a lot of track experience which may be helpful but he's a more aggressive trackie than myself. Some drivers like to push to the limit but I prefer to always stay a margin within it - I still have fun in my own sweet way.
Offline QD MBE
  • -Receive: 102
« Reply #7 on: December 02, 2010, 08:57:26 pm »
****Cough *****  Do not REPEAT Do not look at the scenery, or lose your way on the track!  ****Cough*****
I have only done track days on my bikes, but the advice still holds fast.
Always within your own capabilities, and never faster than your guardian angel can fly!
Or as kevin schwantz advised when riding..............If you see God.................Back off!
Make sure your car is up to it, I got caught out at Pembrey once, I finished the rear tyre off fully on the track, and had to ride 100+ miles to get home on a self made racing slick as a back tyre!
« Reply #8 on: December 02, 2010, 11:21:00 pm »
....A moment I'll never forget! One of the first corners on my first drive on the Nordschleife. You must admit, it's not as obvious as the other 73 or so corners are!
Wasn't that in Belgium?  :laugh:
Offline Janner_Sy
  • -Receive: 113
« Reply #9 on: December 02, 2010, 11:52:14 pm »
if in doubt flat out. :wink:
not to sure on the kink as you exit the corner in your pic though :laugh:
Offline tony_danza
  • -Receive: 112
« Reply #10 on: December 02, 2010, 11:58:54 pm »
Tuition, tuition, tuition.. until then - slow in, fast out.
Depends on your style and car set up too, I use oversteer and trail braking, this comes with time and confidence, so my picture would look very different to yours. Some people never feel comfortable with this and prefer to have a 'planted' back end. In this instance stick to SI/FO otherwise you'll just overcook it and understeer.
Oh, you missed the apex too  :signLOL:
Sideways yo!
« Reply #11 on: December 03, 2010, 12:15:25 am »
*Googling trail braking*
This should be moved into the track related section... Mods?
Offline Janner_Sy
  • -Receive: 113
« Reply #12 on: December 03, 2010, 08:15:57 am »
as TD said.  tuition is key.  more often than not if im at a track day and havent used the track before ior for a while i always get an instructor out with me. just for a few laps
Offline jabbalad
    • Jabbasport
« Reply #13 on: December 03, 2010, 09:49:55 am »
As danza said really,
it completely depends on how the car is set up, if its relatively standard the car wont allow you to drive it how a properly sorted fwd car should be driven in the track, but then saying that if its set up properly it would be really nervous to drive fast on a back road blast due to it relying on having temprature in the rear tyres...
I would start off with how you have drawn it in your pic, folowing the basic rule of thumb of brake in a straight line, then build the speed through the corner.
if you want to go past this stage you will need to throw that rule of thumb out the window, then it becomes a case of how much confidence you have to be able to slide the car! As tony said, You then start braking deeper into the corners and using the power to control the degree of slide you have going through the corner, if its done right you should have very little slide but enough to be able to keep the throttle on without worrying about any sort of understeer... so its more of a fast in fast out technique! you have to be very smooth with this tho not using much steering input at all!
The beauty of fwd is that you can have a massive moment and still get away with it, but just remember to take the opposite lock off just as quick as you put it on... otherwise you will be going back the opposite way haha
12.7 santapod... soon to be quicker :-)
Candy White Edition 30; Custom KW clubsports, Eibach hollow arbs, Jabba remap, BTB Exhaust, Twintake, Autotech HPFP, Team Dynamics wheels, VWR Big Brakes.
Offline tony_danza
  • -Receive: 112
« Reply #14 on: December 03, 2010, 10:55:32 am »
As a means of explaining what a cautious approach is, this is my mate Nige following me on a lap of Oulton a few weeks back. Was very cold & greasy, so I'd turned off idiot mode and was back into being smooth.
It's not without fault (getting used to the track new car) but between the two cars you get an idea of what makes a safe lap by being SI/FO. Braking before turn in, power through the bend etc etc.
I'll try finding a FI/FO lap for comparison.
Sideways yo!
