Author Topic: Tips for moving car shots?  (Read 4046 times)
Offline GlennD
« on: December 11, 2010, 07:31:24 pm »
Anyone got any more tips as I do want to get better at this.  :notworthy:
Best one imo that I have done so far.  :wink:
Offline andrewparker
  • -Given: 32
  • -Receive: 78
Re: Tips for moving car shots?
« Reply #1 on: December 11, 2010, 09:01:42 pm »
Move the camera with the car. A wider aperture will result in a blurred background with your subject (the car hopefully) in focus.
  • -Given: 32
  • -Receive: 78
« Reply #2 on: December 11, 2010, 09:05:26 pm »
I'd also suggest getting tight on your subject. Where your photo falls down is the superfluous surroundings. Of course you can crop in post-processing, but I think it's better to get it 90% there in camera.
Offline scotta
  • Edition 30
« Reply #3 on: December 11, 2010, 09:15:35 pm »
Firstly What camera are you using?
Secondly read this http://www.avforums.com/forums/digital-photography/691137-had-bash-motorsport-photography-guide.html
Shutter Speed is more important than aperture settings - Example
The above was taken with the following settings.
Exposure 0.025 sec (1/40)
Aperture f/25.0
Focal Length 71.3 mm
ISO Speed 400
Using Shutter priority mode and hard setting the shutter speed will allow the camera to adjust the aperture for changing light when you pan.
« Last Edit: December 11, 2010, 09:34:17 pm by scotta »
Offline GlennD
« Reply #4 on: December 11, 2010, 09:53:22 pm »
Thanks, I knew it would something like that.
Its a D3000 but I've just got the 55m lens really need to get the 70-200m for things like this.
Cheers!   :drinking:
Offline scotta
  • Edition 30
« Reply #5 on: December 11, 2010, 10:25:32 pm »
Cheers!   :drinking:
The 18 - 200mm 3.5 -5.6 AFS VR is a cracking lens for the price. Thats what i use. Next purchase on the list will be a 70 - 200 2.8 Bit steep at £1600 tho  :xmaspresent:
Using the 3d tracking on your AF settings will help - tells you how to do that here http://www.kenrockwell.com/nikon/d3000/users-guide/index.htm
« Last Edit: December 11, 2010, 10:29:20 pm by scotta »
Offline Norbreck21a
« Reply #6 on: December 11, 2010, 11:22:29 pm »
TBH, when I'm doing panning shots of vehicles in motion, I rarely use AF. Normally I prefocus on an area on the track that the car will pass though and use this.
As Andrew said in the second post, panning is the technique. you need to master. Looks easy but takes some practice. The mistake that many people make is to not smoothly following the action BEFORE and AFTER releasing the shutter. Learn to follow the action and smoothly pan and  press the shutter (motor drive is good for this) then keep on panning after you have taken the shot. Also, squeeze the shutter release, don't stab at it.
Start with shutter speeds of about 1/250 to 1/125 sec to start with, until you have mastered the technique, then when you are confident, start lowering the shutter speed. Depending on the focal length of the lens in use, aim to drop down to somewhere between 1/60 to 1/30 second for that ultimate creamy blurred background. Don't forget also, if you are shooting with a stabilised lens (VR for Nikon and IS for Canon), if the lens offers it, set the VR mode to "Active" from "Normal". In this mode the camera assumes you are panning or shooting from a moving vehicle and therefore only looks to reduce shake in the vertical plane and not the horizontal (panning) plane.
Choice of lens focal length is equally important. Depending on how far away from the action you are and what type of camera you are using (I.e. a DSLR with a cropped or full frame sensor, or a bridge all in one camera), I normally use either a 200 or 300mm lens and use my cropped Sensor DX camera to give an effect Focal length of between 300-450mm. Remember, the longer the focal length, the shallower the depth of field will be (the area behind and in front of the actual plane of focus that will be rendered sharp), so long lenses  are good for defocussed and busy backgrounds. However long lenses tend to be more difficult to handle and are generally heavier. Therefore my final piece of advice would be to use a monopod (not a tripod). The monopod will allow you to pan even more smoothly and also take the weight of the camera/lens combination making it a more comfortable experience.
As with most things, practise makes perfect.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=c6p6r6brgk2m1matsbs8hv0s60&/topic,19740.0.html
« Reply #7 on: December 11, 2010, 11:26:22 pm »
Sometime superfluous can be a good thing!
As above... practice practice practice!
Offline GlennD
« Reply #8 on: December 11, 2010, 11:56:26 pm »
[img width=640 height=427]http://farm5.static.flickr.com/4086/5023013075_8dedaab356_z.jpg/img]
I know tell me about, just haven't had the motivation to go out in a last few months.  :sad1:  :chicken:
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« Reply #9 on: December 12, 2010, 04:57:24 pm »
I am far from an expert on this but for me the photograph needs to convey the speed of the car. I try to get the car in focus but to blur the wheels giving the impression of speed.
Offline GlennD
« Reply #10 on: December 12, 2010, 05:38:39 pm »
Just been looking back over my York Raceway 2010 photos and here are my favourites:
Golf GTI ED30 - over 400BHP!  ;)
Jabba Vs Pirelli:
Split Second Dragster:
Twin-mid engined Mini:
Audi TT RS:
Golf GTI Pirelli:
Golf GTD ( Migloir Detailing LTD ):
Jaguar XJ:
Camaro (?):
The Shogun (DM Racing):
Audi TT RS Vs a Honda Civic:
Rodzilla:
Chevy Nova:
A rather nice BMW (F10?):
Cortina (?):
10 second bike (balls of steel or what? :eek:):
Audi S8:
French Van...? A sleeper, well, it made me fall to sleep! :p
BMW M5:
AC Cobra (probably replica but still very fast):
Dodge Challenger - SRT8 HEMI :
Fastest Pug ever!
Offline Rich
    • Carpet Underlay
« Reply #11 on: December 26, 2010, 11:00:12 am »
Awesome pictures mate :notworthy:
Offline divweir
« Reply #12 on: December 27, 2010, 07:25:33 pm »
lovely pictures :congrats:
Sig to big.
MPS
« Reply #13 on: February 04, 2011, 08:55:24 pm »
Oh lordy look at the reflection on that TT!! Absolutely stunning!! My mission, should I choose to accept it, is to get my mk5 GTI's paintwork to that calibre this weekend.  :laugh: Noo fookin chance  :grin:
Offline warrenlord
« Reply #14 on: February 17, 2011, 11:34:51 pm »
some great moving shots.
