Author Topic: What brakes should I get?  (Read 5047 times)
Re: What brakes should I get?
« Reply #15 on: December 20, 2010, 12:12:14 pm »
6 pots oh and wait for Hurdy with his 10 pots  :signLOL:
Offline QD MBE
  • -Receive: 102
« Reply #16 on: December 20, 2010, 12:16:20 pm »
R32 rears are vented vs GTI's solid too.
Agreed, S3 is 310 x 22mm, uses the same pads, hoses as the Std rear set up on the GTI.  The caliper is a wider version of the standard GTi version (to take into account the 10mm thicker disc - standard GTI is a 286 x 12mm disc)
Offline tony_danza
  • -Receive: 112
« Reply #17 on: December 20, 2010, 12:20:39 pm »
Matt, you fail until you do the tin o'veg test!
Best thing I ever bought for that car those brakes, I'd have them every single time.
Sideways yo!
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #18 on: December 20, 2010, 12:22:25 pm »
You mean these i have laying in my living room  :xmassmiley:   :drool:
Over the top mod list ;o)
« Reply #19 on: December 20, 2010, 12:24:09 pm »
ok i will do a tin pic test  :signLOL:
Offline QD MBE
  • -Receive: 102
« Reply #20 on: December 20, 2010, 12:26:16 pm »
996TT brakes, with 355mm discs
« Last Edit: December 20, 2010, 12:29:42 pm by stokeballoon »
  • -Given: 243
  • -Receive: 154
« Reply #21 on: December 20, 2010, 12:38:33 pm »
very nice brake setup, but requiring spacers for std. rims right??
Offline QD MBE
  • -Receive: 102
« Reply #22 on: December 20, 2010, 12:43:38 pm »
With the Ed 30 Std Pescara they would need a spacer.  The rim shown is a BBS VZ 8.0J with an ET44 offset.  3mm clearance at the caliper face, so no spacers needed.
The disc is actually taller than the Std Gti 312mm disc, so it takes the centre line of the disc closer to the track rod end.
The Standard Ed 30 rim is really restrictive, being 7.5" wide.
Offline POC
« Reply #23 on: December 20, 2010, 01:00:08 pm »
Lol @ the willy waving  :wink:
I feel inadaquate!
« Reply #24 on: December 20, 2010, 09:17:01 pm »
This is my set up Al.
But seeing as you just asked front or back for the R32 kit, i would defo go fronts.  :xmassmiley:
  • -Given: 380
  • -Receive: 442
« Reply #25 on: December 20, 2010, 09:36:51 pm »
The FWD Golf does approx 80-85% of braking on the front, I was told by AP Racing. So front brakes are the most important.
As stokeballoon has posted, adding the S3/R32 vented rears noticeably make the whole hard braking experience feel incredibly well planted and stable. You have to completely rethink your braking distances or you then have to get back on the throttle to reach the corner or roundabout!
I'd much rather have powerful brakes and not need them, than need them and not have them. I've only needed them 3 or 4 times in emergency but phew!
Offline POC
« Reply #26 on: December 20, 2010, 11:03:26 pm »
Crappy phone pics but here are my R32's
« Reply #27 on: December 20, 2010, 11:06:19 pm »
They look massive under 17s!! Dont you have the rotors on the wrong sides tho?
Offline POC
« Reply #28 on: December 20, 2010, 11:08:22 pm »
Dunno, Ive always run the grooves that way, my understanding is that the direction of the grooves doesnt effect braking performance, its wether the veins are curved or straight that effects cooling?
« Last Edit: December 20, 2010, 11:13:46 pm by POC »
« Reply #29 on: December 20, 2010, 11:14:24 pm »
Not sure to be honest with you... i just thought that the slots should run the other way! (might be VERY wrong tho)
