Author Topic: RNS 510 Version B  (Read 5723 times)
Offline Johnny_tro
RNS 510 Version B
« on: January 02, 2011, 12:15:51 am »
how do I know if my car needs this extra part(unit) to stop my battery going flat?
'VANDALISED' MK5 GT :( - RNS510 H, Bluetooth Armrest, MDI, 50gb hard drive, I can't park  sensors, Cruise Control, Highline Display, MFSW, Heated Seats, Remote Aux Heating System (Heats and Vents) Winter Pack, Heated & Folding Mirrors, Puddle Lights, Xenons, Headlamp Washers, Heated Washers, Auto lights and wipers, LED's, GTI brakes,, black R32 roof lining, Scirocco Rear View, Rear Footwell Lights
Offline chowgar
Re: RNS 510 Version B
« Reply #1 on: January 02, 2011, 12:18:24 am »
what is your car?
Offline Johnny_tro
« Reply #2 on: January 02, 2011, 12:20:42 am »
2004 mk5 gt tdi
Offline chowgar
« Reply #3 on: January 02, 2011, 12:29:54 am »
I'll take a punt and say yes... mines a 05 gti andi needed a canbus upgrade... have you checked to see what version you have fitted?
Offline Johnny_tro
« Reply #4 on: January 02, 2011, 12:34:47 am »
Have Not no.....because I don't know where it's located let alone what it actually does :(
are they £££ and do they need a coding done?
Offline chowgar
« Reply #5 on: January 02, 2011, 12:41:03 am »
off the top of my head 70-80 notes less if you have a look about on ebay.... if i remember its located under the steering wheel in the footwell... do a search there is a load of info about on the upgrade...
yep it will all need recoding
Offline Johnny_tro
« Reply #6 on: January 02, 2011, 12:49:08 am »
OK, when buying a RNS510 should I pay note to anything specific? other than making sure it has the code with it?
Offline Johnny_tro
« Reply #7 on: January 02, 2011, 12:56:00 am »
 canbus < do I find what model I currently have fitted and get the next one up or something?
« Reply #8 on: January 02, 2011, 03:54:30 am »
If you do a search, you'll see what you need including part numbers, price and an installation guide.
Basically any canbus version later than (and incl.)  L will be fine. The L version was introduced in 2007 cars onwards. You'll also need to get the unit coded as it will be "blank" and won't have any settings on it.
Offline dp2
« Reply #9 on: January 11, 2011, 06:59:22 pm »
Can the version B be upgraded to the latest maps with postcode search?
Offline Dai-Click
« Reply #10 on: January 11, 2011, 07:24:54 pm »
I have a version "K" can bus for sale if that will cure any battery drain issues
1K0 907 530K    HW:1K0 907 951
Offline mortygttdi
  • -Receive: 146
« Reply #11 on: January 11, 2011, 09:27:09 pm »
Johnny if you take the ashtray out on yours the Canbus should be behind there,  after 2004 they where above the pedals and after 2006 they where behind the relay plate above the small cubby.
Darren
« Reply #12 on: January 12, 2011, 02:12:16 am »
Yes but you need to update the firmware too.
Offline Johnny_tro
« Reply #13 on: January 12, 2011, 04:48:54 pm »
which is more upgradable?
The B or C?
i.e can the B unit be simply upgraded to the same standard as the C? or does the C have greater potential than the B version?
Offline dp2
« Reply #14 on: January 12, 2011, 06:18:26 pm »
Would I need the canbus then? I've read that the version B doesn't suffer from battery drain, but i've also read that certain firmwares can cause battery drain with the version B.
