Author Topic: How to Snow foam without.......  (Read 9068 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=olaoqeenhblc0djas48p7plj50&/topic,19740.0.html
« on: January 04, 2011, 03:46:05 pm »
... a power washer... or a hose pipe??
Any ideas guys??
Rich
Offline edd666999
  • -Receive: 89
Re: How to Snow foam without.......
« Reply #1 on: January 04, 2011, 03:48:10 pm »
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #2 on: January 04, 2011, 03:50:21 pm »
« Reply #3 on: January 04, 2011, 04:06:56 pm »
Can you get that in bulk packs?  :chicken:
« Reply #4 on: January 04, 2011, 04:09:05 pm »
Pretty much impossible rich
« Reply #5 on: January 04, 2011, 04:16:13 pm »
Whats the best alternative to SF? Just want something to spray on to loosen the dirt a bit before attacking if with a MF washmit!
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #6 on: January 04, 2011, 04:17:45 pm »
http://www.cleanyourcar.co.uk/washing-and-drying/super-spray-hose-end-sprayer/prod_335.html
worked for me , until I got a karcher for xmas/birthday  :signLOL:
now I need a proper lance
Red ED35 5dr DSG
BLOG | BUILD
« Reply #7 on: January 04, 2011, 04:19:39 pm »
Try looking on dw for optimum no rinse. It's a great product to use when you can't find a hose pipe. I wouldn't recommend washing your car like this when it's really dirty though
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #8 on: January 04, 2011, 04:24:34 pm »
Ive previously used a hand spray bottle to put a detergent and water mix on the car, left that to reside before rinsing with several buckets of water and then two bucket, it doesn't foam up but you at least get the chemical action to loosen the grease and dirt.  Its a bit laborious and doesnt foam on impact but needs must sometimes.
Offline keith
« Reply #9 on: January 04, 2011, 04:41:22 pm »
Valet Pro's Ph neutral snow foam can be used via low pressure hand/pump sprayer and works very effectively but to rinse of you need a hose at least.
« Reply #10 on: January 04, 2011, 06:17:31 pm »
Ahh so that might be an option! Thanks!  :happy2:
Can you recommend a good hand sprayer? I notice that you do forum discount on cleaning products... whats the deal?
« Last Edit: January 04, 2011, 06:19:36 pm by richwig83 »
Offline keith
« Reply #11 on: January 04, 2011, 07:46:23 pm »
15% off the shop products
I have been trying out some over the festive period, I just got a 6L Kwazaar that uses a hand held lance, but tried out the pH Neutral in a 2L low pressure spray.
Kwazaar seem a good brand but they go under MercuryPro and another name.
« Reply #12 on: January 04, 2011, 08:13:04 pm »
I cant seem to find either online... do you have links to where you bought yours?
« Reply #13 on: January 05, 2011, 12:39:35 am »
For snow foam, you need a good mix of air and you need pressure. Using a bogstandard chemical sprayer bottle will do bugger all. Even using one of those hand-held things just won't be anywhere near as effective as a proper lance.
ONR - something I've thought of dabbling but TBH not worth the potential damage. Quite a few people on DW really rate it though.
It might be better to take it to a detailer and get it looked after properly rather than wasting money on products you're probably end up replacing any way.
Offline keith
« Reply #14 on: January 05, 2011, 08:23:59 am »
1.5L that can be used with agressive chemicals this is called a power spray but is made by kwazaar there are cheaper version to be found in garden centres from about £3.50 >
