December 20, 2025, 06:01:36 pm
All Things Mk5
How to Guides / Troubleshooting
Abs/ESP problem
Topic: Abs/ESP problem (Read 1693 times)
wallybanger
Taking part
-Given: 0
-Receive: 0
Abs/ESP problem
February 06, 2011, 11:03:39 am »
Had no problems at all with the car untill last week when i put a set of BBS ch 9x18s on last week all running the same tyres and same pressures now once you start driving no problem untill 40 mph + then the lights for the ABS,ESP and flat tyre lights a come on and wont go off untiil car is turned off and on again . i have checked tyre pressures and all are fine . really annoying warning lights but abs still seems to work esp def isnt but lol
edd666999
Just look at my post count
-Given: 24
-Receive: 89
Re: Abs/ESP problem
Reply #1 on:
February 06, 2011, 12:02:22 pm »
have you pressed and held down the tyre pressure warning button till it pings at you
stealthwolf
-Given: 306
-Receive: 292
ED30 No.1412
Re: Abs/ESP problem
Reply #2 on:
February 06, 2011, 12:08:03 pm »
I posted up about a similar problem. On mine, one of the ABS sensors broke and since the entire system is linked, you get errors in abs/tcs/tp lights - all were yellow. Tyre pressures, brake fluid etc were all ok.
Replaced under warranty.
The
GTI
isn't just a machine. It's very much a living, breathing thing.
All Things Mk5
Abs/ESP problem
