Author Topic: Retro fitting headlamp washers - bit of advice needed  (Read 23551 times)
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« on: February 09, 2011, 07:24:49 pm »
Some advice please guys, (thanks to Golfman and EddieNL for their advice so far :happy2:) I am about to gather all the bits for the retro fit of the headlamp washers but I have got a few questions that I can't answer without ETKA.
Is the following all I need?
I already have the Kufatec washer loom. The list I have managed to gather from one of Morty's posts (for a tdi) so far is:
Pump for headlight washers - 3B7 955 681
N903 038 01 this is the O-ring for the pump
Gasket - 431 955 465A
Lift Cylinder - 1K6 955 978A x 2
Speed nuts - n909 591 01 x 4 - 2 per cylinder
Nozzle carrier Left - 1K6 955 103
Nozzle carrier  Right - 1K6 955 104
Cover cap Left - 1K6 955 109 GRU --------- Are these for the GTI?
Cover cap Right - 1K6 955 110 GRU --------- Are these for the GTI?
Adaptor - 1T0 955 665
Connector - 1J0 955 665E x 3
Hose in 10m length - 1J0 955 964F ----------Do I need a full 10m? Apparently its £8 a metre??
Angled piece - 1J0 955 665A
Junction - 7L6 955 873
Terminals - 1J0 955 846 x 8
Cable tie with teminal socket - 3D0 971 838E x 1
I am told I may need these too, how I can check?
Water level for the washer bottle.
Water level switch  - 7M0 919 376
O ring - 7M0 919 382
Flat contact housing - 7M0 973 202
Questions
Are all these for the GTI? I have been told that most of the bits are around a fiver from VW with the exception of the pump (Approx £50).
I presume the job involves......bumper off, existing water bottle off, hole drilled for pump in existing bottle, attach and route loom from pump to cecm, attach water pipe to bumper, attach lift cylinders and fit new bumper mouldings, code in via VCDS...... Is that close? :rolleye:
Does anyone have the full costs involved here?
I have found this pump on ebay that seems to be a new copy, maybe I would regret getting this :laugh: Would you recommend a VW pump?
[ebay]180385085419[/ebay]
Anything else required?
Hesitating to bug Darren on this one (that will come later mate  :signLOL:)
Offline mortygttdi
  • -Receive: 146
Re: Retro fitting headlamp washers - bit of advice needed
« Reply #1 on: February 09, 2011, 08:12:41 pm »
I'm going to jump in any way buddy :wink: most of them item numbers are for the normal golf bumper and R32 but not GTI they use different shaped jets but the part number for the jets is the same minus the A on the end.
Apart from that you more or less have the know how, also that is the same pump has what I have? Think I paid £17 and have had a couple of them for other people, they have been fine.
Just on a side note measure from the one side of the bumper to the other and add a little extra and thats the amount of hose you'll need. Make sure you have a very sharp knife or cutters.
Darren
« Last Edit: February 09, 2011, 08:16:28 pm by mortygttdi »
Offline bodger00
  • -Receive: 20
« Reply #2 on: February 09, 2011, 08:26:42 pm »
Cheers Darren, I knew you would know :happy2:
Probably best to start with the pump & the jets then. Cheers for the measuring tip. I will build up the bits over time.
Cheers  :drinking:
« Last Edit: February 09, 2011, 08:28:24 pm by bodger00 »
Offline mortygttdi
  • -Receive: 146
« Reply #3 on: February 09, 2011, 08:31:22 pm »
Keep looking on ebay I found about 3 sets of jets on there that i've used on retrofits.
Happy hunting mate, just let me know if you need any thing, I do have about a meter of hose but its no good for the lengh across the bumper,
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: February 09, 2011, 08:35:45 pm »
Does the golf use a larger washer bottle for Xenon equipped cars?
Stu...
« Reply #5 on: February 09, 2011, 08:39:12 pm »
5.5L i think, for cars with washers.
Offline mortygttdi
  • -Receive: 146
« Reply #6 on: February 09, 2011, 08:49:44 pm »
Yes it does Stu although the marks are there so you can drill out the existing bottle, and to be honest I use my washers quite a bit with this sh** weather and it still lasts some time...
Darren
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: February 09, 2011, 08:51:09 pm »
If a job's worth doing .....................  :signLOL:
Stu...
Offline mortygttdi
  • -Receive: 146
« Reply #8 on: February 09, 2011, 08:57:46 pm »
Your absolutely right mate, which is why I have the bottle sat in my shed waiting to go on :grin: it'll get done just like the other million and 1 thing I need to do.. :happy2:
Darren
Offline red-snake
  • RED-SNAKE
« Reply #9 on: February 10, 2011, 12:24:43 am »
i have a set of washer jets and the pipe line if any one wants to make me an offer for them
Offline Comms
« Reply #10 on: April 03, 2011, 11:53:24 pm »
How did this one go for you bodger?
I am looking to do this as im very close to having some xenons fitted.
Is that list of parts everything you needed for your gti and also did you fit them yourself or have someone do it for you?   :smiley:
Offline bodger00
  • -Receive: 20
« Reply #11 on: April 06, 2011, 08:17:12 pm »
I'm not there yet Comms :sad1:
I have all the bits and pieces now but I'm in need of some coding assistance to get it all in and working (Darren has kindly agreed to assist when he is free). I am going to do a retro fit properly with washers, auto levelling and the xenons fitted at once.
Its not the full list above, although its quite close. I will have some spare hose soon if your interested as my parts guy gave me a full 5 metres (which I doubt I will need). I will need to fit mine first though.
Ive just finished spraying my bumper mouldings that attach to the jets and they have come out quite well. Be careful you get the right ones if you buy them new as there are 4 listed.
Offline alexperkins
  • -Receive: 99
« Reply #12 on: April 06, 2011, 08:41:20 pm »
What was the cost of it all bodger...im currently pricing it up for mine. PM me if you wish  :happy2:
Offline bodger00
  • -Receive: 20
« Reply #13 on: April 06, 2011, 08:59:07 pm »
If you are wanting new kit then your looking at approx £150 inc the bumper mouldings. Obviously if you can get the parts second hand then its likely to be cheaper. If your a keen bargain hunter (mentioning no names) then you can get the lot for about £50.
Offline alexperkins
  • -Receive: 99
« Reply #14 on: April 06, 2011, 10:00:01 pm »
That just the washers, or the levellers too?
