Author Topic: Wing mirror indicator not working?  (Read 14092 times)
Offline big al
« on: February 10, 2011, 03:25:46 pm »
Hi all,
Realised the other day that this is not working when I indicate, It's not a bulb issue as they run off LED's.
Been quoted £22+Vat for a new board, but wondered if anyone could enlighten me on what the problem may be or if it's just a dodgy circuit before i spend my 'hard earned' cash?
Thanks  :happy2:
Offline mortygttdi
  • -Receive: 146
Re: Wing mirror indicator not working?
« Reply #1 on: February 10, 2011, 09:30:59 pm »
If you have vcds get it plugged in and do a test on the indicator.
Failing that get the door card off and check the connector is in properly take it out and push it back in.
Darren
Offline VWKD
    • VWKD
« Reply #2 on: April 20, 2011, 04:42:31 pm »
Did you resolve this issue BA ?
Mine has just failed the MOT as the drivers side mirror indicator is not flashing and no amount of technical taps is gonna get it working.
How does one replace the indicator part ?
1971 T2 Camper
1972 Triumph Spitfire MkIV
1999 Passat TDI Running On Chip Fat
« Reply #3 on: April 20, 2011, 04:53:53 pm »
There's a link somehwere. Type inpro into the search and look for a link in one of the threads.
Offline VWKD
    • VWKD
« Reply #4 on: April 20, 2011, 05:10:15 pm »
Is this it
Is it common for these to fail ? or should I be checking other things before commiting to buying a new one?
I assume it will be a stealer for a new one ?
cheers
1971 T2 Camper
« Reply #5 on: April 20, 2011, 05:37:21 pm »
Yup. You can either go with OEM or take advantage to go for smoked ones.
Offline big al
« Reply #6 on: April 20, 2011, 07:07:55 pm »
I have just had an MOT, and this was not raised as an issue (not sure if they even noticed it)
Have not got around to fitting mine yet, going to wrap them orange I think.
Bought mine off ebay for £15 , £9 cheaper than the stealers, and a genuine part too.
Offline VWKD
    • VWKD
« Reply #7 on: April 21, 2011, 10:29:03 am »
Managed to get to Stealer for opening time this morning get new indicator unit strip and fit and to the MOT place for 9.. hopefully they'll squeeze a re-test in at some point today.
Cheers all for your assistance.
1971 T2 Camper
