Author Topic: 'screech'  (Read 3087 times)
Offline Russ_leeds
'screech'
« on: February 10, 2011, 03:33:45 pm »
hi all i fitted my itg maxogen yesterday and when i took it for a test drive im getting a screech, high pitched wistle between 3k-4k it seems louder when under load.
any ideas what could cause this?
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline cmdrfire
    • Commander Fire - my blog
Re: 'screech'
« Reply #1 on: February 10, 2011, 07:03:00 pm »
Ooh, my dbilas used to do this. Replaced it with the ITG unit. Make sure you've tightened up all the clips over metal and there are no leaks anywhere, especially where it mounts onto the OEM hardware.
Offline v2brett
Re: 'screech'
« Reply #2 on: February 10, 2011, 07:36:37 pm »
i think it may just be a sound you get when you fit an intake fella, i know twintakes make the same noise on Wot
Still Here!
Offline mattypgolf
Re: 'screech'
« Reply #3 on: February 10, 2011, 07:41:03 pm »
my neuspeed did the same... didnt like it so have taken it off....
TR dsg, stage 1 r-tec map, bbs ch in gloss black, black roof and badges, colour coded, neuspeed hybrid intake, cat back exhaust..
Offline Russ_leeds
Re: 'screech'
« Reply #4 on: February 10, 2011, 09:48:33 pm »
i was thinking the diverter valve may have a split in it so was gonna try a rev d and see if that stops it
Offline keano
  • -Given: 79
Re: 'screech'
« Reply #5 on: February 11, 2011, 10:26:57 pm »
Could you describe the noise as 'blowing (oooh err) down a recorder too hard?"  It is a weird harmonic noise.
I think this is fairly common in some intakes. Especially the Neuspeed P-flo
:confused:
Offline Russ_leeds
Re: 'screech'
« Reply #6 on: February 11, 2011, 11:27:52 pm »
 :signLOL:yeah suppose it could be described as that doesn't seem as loud today maybe im just getting used to it
Offline truegrit
Re: 'screech'
« Reply #7 on: February 12, 2011, 02:26:05 pm »
Get the same sound with my ITG -bit scary at first but i really love it now . Get the right bit of road or tunnel  , wind down the windows and put your foot down - it screams like a banshee!Luv it ! :laugh:
  • -Given: 380
  • -Receive: 442
Re: 'screech'
« Reply #8 on: February 12, 2011, 03:13:49 pm »
....My Twintake doesn't - Not a 'screech'. I interpret the word screech to mean a sound which is harsh and metallic like some brakes can do (not mine).
Offline cmdrfire
Re: 'screech'
« Reply #9 on: February 12, 2011, 03:14:38 pm »
My car with the ITG intake just fitted, before I got the APR RSC done
<a href="http://vimeo.com/moogaloop.swf?clip_id=10509157&amp;amp;server=vimeo.com&amp;amp;show_title=1&amp;amp;show_byline=1&amp;amp;show_portrait=0&amp;amp;color=&amp;amp;fullscreen=1" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://vimeo.com/moogaloop.swf?clip_id=10509157&amp;amp;server=vimeo.com&amp;amp;show_title=1&amp;amp;show_byline=1&amp;amp;show_portrait=0&amp;amp;color=&amp;amp;fullscreen=1</a>
Vimeo link for ithing users:
Offline Russ_leeds
Re: 'screech'
« Reply #10 on: February 12, 2011, 05:22:01 pm »
ok maybe screech was a little off, as described above as a flute type sound :signLOL:
  • -Given: 380
  • -Receive: 442
Re: 'screech'
« Reply #11 on: February 12, 2011, 06:14:23 pm »
A flute, you say....
I play flutes....
Offline v2brett
Re: 'screech'
« Reply #12 on: February 12, 2011, 11:06:51 pm »
i sometimes get a slight flute/whistle noise from mine as above ^^,  i just guessed the the Op described the whistle as a screech  :happy2:
put the flute away  :signLOL: :signLOL:
brett
Still Here!
