Author Topic: Problem with RVC - with error code  (Read 5107 times)
« on: February 14, 2011, 03:32:56 pm »
Had it fitted by SteveP several months ago. Since then, it's been brilliant. A couple of times, it's not worked but this is rectified if you select reverse a second time.
Yesterday it was fine in the morning but in the afternoon, it didn't work and it's still not working today. If I select reerse gear, you can hear the mechanism working (and the camera pops out). The screen changes to the camera screen but it's blank. Plain black except for the menu on the roght which allows you to alter contrast, brightness etc.
Running 2720 (I think, or at least latest FW) sice Dec '10, RNS v B.
Any ideas?
« Last Edit: February 15, 2011, 08:40:45 am by stealthwolf »
Offline markymark
Re: Problem with RVC
« Reply #1 on: February 14, 2011, 03:47:05 pm »
I had similar issues with mine, SteveP resolved it somehow but cant remember what he did. I think he scanned it with VCDS. My advice send MrP a pm! :happy2:
Offline PND
  • -Receive: 62
« Reply #2 on: February 14, 2011, 06:50:21 pm »
Have you tried resetting the RNS?  Press these three buttons all together.. '<' and '>' top left and 'i' top right.. I think that's right!
I've had it happen once or twice with mine..
Paul.
Offline Rob GTI
« Reply #3 on: February 14, 2011, 07:06:24 pm »
The RNS reset above worked for me. Also might want to check the obvious i.e. no dirt / cr*p on the camera itself.
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
« Reply #4 on: February 14, 2011, 07:22:43 pm »
I've tried the reset several times to no avail. The camera looks fine.
Offline Rob GTI
« Reply #5 on: February 14, 2011, 10:31:50 pm »
The only other thing that gave me this problem was when I was installing it the connector into the badge camera wasn't secure. Worth a look ??
« Reply #6 on: February 14, 2011, 11:07:04 pm »
I've had it for almost a year (installed in March 2010) without problems. Don't know why it would suddenly go blank now.
Re: Problem with RVC - with error code
« Reply #7 on: February 15, 2011, 08:42:55 am »
Ran VCDS this morn (took it with me to work!).
Can't post entire code as on iPhone but error is:
02873 - control module for back-up camera (J772)
004 - no signal/communication
Any ideas?
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #8 on: February 15, 2011, 09:06:11 am »
That looks like a loose wire, either at the camera or at the back of the stereo, does the power feed for the camera have a separate fuse? could be worth a check.
Offline Rob GTI
« Reply #9 on: February 15, 2011, 09:10:12 am »
I had a problem with the connector on my accelerator pedal putting the car in limp mode, it turned out the connector was not properly plugged in. This was after nearly a year of ownership, so don't rule it out, you never know it might not have clicked in properly and has been jarred out by bumpy surfaces.
« Reply #10 on: February 19, 2011, 01:23:22 pm »
Okay, after much faffing around, I managed to rip off the boot trim. Checked all of the connections and they seemed fine. Couldn't see anything that was loose.
Ripped open the rns510 and checked the connection there - secure.
Still no joy. Any ideas?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #11 on: February 19, 2011, 07:18:15 pm »
It could be something on the loom in the boot, let me know when your free some over the next few weeks and I will swap it over for you  :happy2:
« Reply #12 on: February 19, 2011, 07:40:00 pm »
Thanks mate. Will PM you about dates.  :happy2:
Also had a gander at the drain pipe. Hacked a megs' bottle straw and it seems to fit perfectly. It'll do for now.
Offline marko
« Reply #13 on: November 10, 2015, 11:57:52 am »
Any more info on the fix for this!!
Having same issue with mine..perfect 2 days ago and now just black screen
 :ashamed:
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #14 on: November 10, 2015, 01:43:14 pm »
 :ashamed:
Might be one of the 3 wires has come off the camera.  Its quite common because the wires are really tight so when the camera the wires get pulled too, over time it will cause damage.
Sent from my GT-I9505 using Tapatalk
