Author Topic: Mfd2 right circle button stopped illuminating.. LED? * pic added**  (Read 2622 times)
Offline ruffrydaz
I have an mfd2 system and the led on the right cirle button has stopped illuminating
I heard these leds go on forever. any ideas what it could be?
« Last Edit: February 18, 2011, 02:32:11 pm by ruffrydaz »
Offline ruffrydaz
Re: Mfd2 right circle button stopped illuminating.. LED?
« Reply #1 on: February 18, 2011, 01:18:25 am »
Heres a pic:
Offline ruffrydaz
Re: Mfd2 right circle button stopped illuminating.. LED? * pic added**
« Reply #2 on: February 19, 2011, 01:45:03 pm »
I dont want to keep bumping but can anyone help please. the button workds fine btw
Could it be anything else except the led failing? if not any guides on changing it?
I know its a small problem but its SO ANNOYING lol
« Last Edit: February 19, 2011, 01:47:35 pm by ruffrydaz »
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #3 on: February 19, 2011, 01:57:12 pm »
I'm no expert but certainly my first thought is that its the LED thats failed.  They do normally have a very long life expectancy but you get duff ones just like everything else.
I would imagine its repairable only if you have a steady hand and are good with a soldering iron.  That sort of thing would bug me too.  Look at it as a good excuse to get and RNS510.
Sepang Blue S4 BE Avant
Offline antonis42
« Reply #4 on: February 19, 2011, 02:21:25 pm »
I had the same problem too.
There are four(4) leds for the button.
The problem seems to be with the circuit board which is on the faceplate.
I had a spare part backplane from my older CD version MFD2,
which I used to replace in my current DVD MFD2; and it worked fine.
So my advice is to get from ebay a spare faceplate only (ive seen some on ebay.de).
best of luck.
Offline ruffrydaz
« Reply #5 on: February 19, 2011, 03:24:09 pm »
Thank you.
Could you lead me to the part you are talking about and cost? and how easy is it to change?
thanks
Offline antonis42
« Reply #6 on: February 19, 2011, 03:51:19 pm »
see here on how to dismantle the unit, its easy,
(thats from touareg mfd2, but its the same procedure, very similar unit, and torx screws).
http://www.clubtouareg.com/forums/f43/diy-how-to-repair-an-rn-s2-dvd-a-k-a-mfd2-47720.html
I swapped the green backplate including the lcd screen.
here is an ebay one, 200 euro.
http://cgi.ebay.de/VW-MFD-2-DVD-Front-Display-MFD2-MFD-2-Bildschirm-/170601880606?pt=Technik_Auto_Hi_Fi_Navigation_Einbau_Navigationssysteme&hash=item27b8aa1c1e
Note that ebay pictures show CD MFD2 version (different buttons).
It doesn't matter, as you can use your silver buttons and plastic face of unit when assembling.
CD unit backplane worked on my DVD unit.
hope that helps
Offline ruffrydaz
« Reply #7 on: February 19, 2011, 04:03:01 pm »
thanks alot mate!
