Author Topic: Mk5 Gti vs Skoda Octavia VRs  (Read 28802 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: Mk5 Gti vs Skoda Octavia VRs
« Reply #45 on: February 20, 2011, 05:39:08 pm »
Your point being????  :P
I'm not the one who can't get under my car when it's jacked up  :booty:
Offline vRS_Pagey
  • -Receive: 59
« Reply #46 on: February 20, 2011, 05:44:26 pm »
You are also slightly overweight?!?!?!  :wink:
I blame the inferior tools and acute angle of the drive way!  :innocent:
RustyGTI
« Reply #47 on: February 20, 2011, 05:50:19 pm »
Nice one, thanks  :happy2:
What DV valve should I replace it with if it does turn out to be knackered?
Can you also recommend what spark plugs / HT leads you guys run?
Russ
...it was actually the Skoda driver who undertook someone on the slip road just before joining the motorway causing them to swerve... :surprised:, shocking bit of driving... :stupid: :smiley:
Or just learn to drive properly  :innocent: :evilgrin:
I'm just teasing mate :P
To check the DV is pretty straight forwards if your handy with a spanner. Just remove the under tray, It's on the rear of the engine on the drivers side. Held in by either 3 x 5mm or 3 x T30 bolts. Just undo those, remove the electrical connector and Roberts your mother's brother.
For a bit of clarity have a look in this thread. It's for a DV relocation but it will show you were it is for you to check :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,17736.0.html
RustyGTI
« Reply #48 on: February 20, 2011, 05:59:30 pm »
If the DV valve is at fault would the drop off in performance be significant? As I must admit it doesn't feel that slow...
+1  :laugh:
@  RustyGTI - Have you inspectyed your dump valve, or are your running the revision D piston type already, could be you have torn diaphram type valve and have not noticed.
Offline vRS_Pagey
  • -Receive: 59
« Reply #49 on: February 20, 2011, 06:00:59 pm »
Russ
This is the latest revision D type, the part number is on the side, cost around 52 quid from the dealers.  :happy2:
Regarding performance, mine still felt quick but I had noticed some flat spots, Carl logged the results a few weeks back and the boost was almost half expected figures.  Since changing the DV the car is awesome again, it does have a stage 1 and EVOMs though.
Edit: have a read of my thread on the Briskoda site, image of the knackered DV in post #12.  You will see that mine was completely split, but afaik even a pin prick in the diaghram will affect peformance.
http://briskoda.net/forums/topic/187114-flat-spot/page__p__2237238#entry2237238
« Last Edit: February 20, 2011, 06:08:04 pm by Pagey1255 »
RustyGTI
« Reply #50 on: February 20, 2011, 06:18:21 pm »
Brilliant, thanks!! See what you mean about the split, that is well and truly knackered!!
Thanks for the part number and picture...the revised 'D' type is an option, do forge also do a version and is it worth just sticking one of those on anyway?
Russ
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #51 on: February 20, 2011, 06:31:53 pm »
Don't bother with the forge. Just stick the OEM one on.
I have an OEM one on my car and it's fine :happy2:
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #52 on: February 21, 2011, 09:44:29 am »
The DV isn't covered by a rear engine tray on the GTI Carl its easily accessible if you get underneath with the car jacked up, you will also want to remove the off-side (drivers side) wheel as that allows you to get a second hand in to support your tool  :grin:  There is also a 4th hex bolt by the DV which is the same size but not related if you remove a bolt with a washer then screw it back in.
If the Octavia has a larger engine cover that could be part of the reason it cuts a cleaner whole in the air. (I know that the non hatch also helps)  :happy2:
« Last Edit: February 23, 2011, 09:30:56 am by Richn83 »
Offline micky 32
« Reply #53 on: February 22, 2011, 10:18:56 pm »
I'm running the D with my KO4 and the OEM works perfect.
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
