Hi guys,
I am having a problem...
I installed DaveB's nqsbbk and I found out that my track rims don't have enough clearance (they fit but the clearance is less than 1mm).
The rims are OEM
Goal anthracite
7.5x17 ET50 .
So, my questions are:
1. Is it safe to use spacers (hub centric ones since they are safer) on the track?
2. With the current wheels and 10mm H&R hub centric spacers should I expect the wheels to rub against the wheel arches?
I have real the 2 or 3 topics regarding using spaces (and regarding spacers failing) but did not find the answer to my questions.
One thing that I found odd is that VolkswagenRacing is using 10mm of built in spacers. Since VWR is using these with stock ET50 wheels I should not have a problem with my rims and the H&R spacers, right? Or is VWR using the carbon fiber wheel arches that have more clearance?
And if VWR is using these brakes with TD ET45 rims the problem gets bigger.
I know that there are 2 types of belts for VWR but which one is getting used for tracking?
My current plan is to sell the OEM Goal rims and buy 17 inch TD's. These have 45 Offset so I only loose 5mm opposed to 10mm if I use the spacers.
But if I do not sell the Goal rims I will be forced to used spacers (more or less, depending if my safety is in jeopardy or not).
Please help with any thoughts you might have.
