Author Topic: Walk and sportlines fitted today...  (Read 2749 times)
Offline aidogti
« on: March 31, 2011, 09:34:47 pm »
Hi lads,  I got WALK and eibach sportlines fitted today plus 4 wheel allignment on my 2005 gti,
took the car out for a bit of spirited driving this evening and lets just say I'm very happy with the result.
The car seems much more flatter in the corners and like i've read there is almost no wheel spin when hard accelerating...
I think these mods are really well worth it.
Ive noticed a slight sqweek from the front passenger side, the guy in the garage said he checked and everything seems fine,
anybody come across the same thing? happens when I go over ramps or bumps...
thanks
Saint Steve
Re: Walk and sportlines fitted today...
« Reply #1 on: March 31, 2011, 09:38:07 pm »
Try spraying wd40 on the anti roll bar bushes, and see if stops it.
mine did this, and this stops it.........for a while
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #2 on: March 31, 2011, 09:38:31 pm »
top mounts? i had my rear sreplaced under warranty on my r32 cos they were squeaky on big hits..
Dom
p,s, PICS!!!
Diesel Daily Hack.
Saint Steve
« Reply #3 on: March 31, 2011, 09:41:49 pm »
Dom
p,s, PICS!!!
I had my front struts, springs, top mount bushes, guides, and it still did it.
it sounds like dry Anti roll bar bushes.( behind front jacking points, in round metal housings, with black rubbers inside. Douse them in wd40 and see if it stops.
Offline Redev
« Reply #4 on: March 31, 2011, 09:42:00 pm »
How much is this WALK kit? Is it essentially a set of bushes?
Black GTI, DSG, Cruise control, MFD2,  Leather, MFSW with paddles, Parrot kit, Xenons, CD Changer, Armrest, Come home lighting/puddle lights, mod list in glovebox waiting for some cash and sunny weather....
Offline aidogti
« Reply #5 on: March 31, 2011, 09:45:28 pm »
Are the ARB bushings easy to get at? i have some grease from whiteline bushings i bought from a previous car..
Offline aidogti
« Reply #6 on: March 31, 2011, 09:48:10 pm »
I bought the WALK from one of the lads on here vRS carl..
Its not just bushings, whole bracket and bushing...
Saint Steve
« Reply #7 on: March 31, 2011, 09:48:13 pm »
Yes, just get on your hands and knees, and you will be able to spray them with the red tube in a can of wd40 to soak them.
If your gonna replace them, it's up on ramps for easiest access.
If squeak goes, then housings off to lube them :signLOL:
« Last Edit: March 31, 2011, 09:51:12 pm by Saint Steve »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=vo0o3um0ev9ipuc29e9e9q7gmi&/topic,19740.0.html
« Reply #8 on: March 31, 2011, 09:49:29 pm »
The front ARB bushes stit on top of the subframe at each side, it wouldn't be easy to grease the without dropping the frame!
Offline aidogti
« Reply #9 on: March 31, 2011, 09:57:05 pm »
I'll try the WD40 and see does it solve it.. even if its only temp..
Can the ARB bushins be replaced or did i read ya have to replace the whole bar....
Saint Steve
« Reply #10 on: March 31, 2011, 10:00:34 pm »
Mine are sprayed monthly, keeps the ickle squeaking mice away :signLOL:
Have no plans to replace mine currently .
Offline aidogti
« Reply #11 on: March 31, 2011, 10:14:46 pm »
And that does the job? has the sqeek got louder at all when they dry up?
Saint Steve
« Reply #12 on: March 31, 2011, 10:26:42 pm »
Hasn't got any worse since I've sprayed them, once a month when I remember, and she's still quiet not enough to warrant spending on new bushes.
Offline gazbutS3
« Reply #13 on: March 31, 2011, 10:30:39 pm »
to change them you need to drop the subframe which means you should really do an alignment check, but I have marked the position of the subframe in several places with marker pen before dropping and put it back in the same place before now
Offline bacillus
  • -Receive: 451
« Reply #14 on: March 31, 2011, 11:18:53 pm »
Are you using the standard shocks with the sportlines?
