April 13, 2025, 06:30:25 pm
All Things Mk5
Mk5 General Area
Torque wrench 1/4 3/8 1/2
Topic: Torque wrench 1/4 3/8 1/2 (Read 1035 times)
parks
Always Involved
-Given: 3
-Receive: 17
Red ED30 No. 1778 Detailing World member
April 03, 2011, 12:42:55 pm »
Bit confused, looking at a torque wrench,
Which type do I need? It's only for taking alloys off really. Wanting a nylon bit too, again, what size?
Cheers!!
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
vRS Carl
Just look at my post count
-Given: 282
-Receive: 240
I'm the F.A.G (Forum Apple Guru)
Re: Torque wrench 1/4 3/8 1/2
Reply #1 on:
April 03, 2011, 01:04:52 pm »
Halfords do a Laser 17mm Socket (which is what you need for OEM wheel bolts) which has a plastic coating over.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_194853_langId_-1_categoryId_165469
I have a Teng Tools torque wrench but generally i just use this extendable wheel wrench.
http://www.amazon.co.uk/Draper-19152-Extending-Wheel-Wrench/dp/B0001K9QGI/ref=sr_1_1?ie=UTF8&qid=1301832248&sr=1-1
With the arm fully extended i just tighten the nuts with that and thats more than enough to keep them on
gazbutS3
-Given: 52
-Receive: 55
Reply #2 on:
April 03, 2011, 01:07:30 pm »
you should never use a torque wrench for un-doing bots/nuts
for torque loading the bolts/nuts on wheel re-fit a 1/2 drive would be best but make sure the range it works in is suitable for the required load
stealthwolf
-Given: 306
-Receive: 292
ED30 No.1412
Reply #3 on:
April 03, 2011, 01:32:46 pm »
I think the car, I bought a breaker bar and a torque wrench, both 1/2 inch drive from the professional range, as well as two of the laser socket extensions (blue sleeve).
Two means you don't have to keep swapping it each time.
The
GTI
isn't just a machine. It's very much a living, breathing thing.
All Things Mk5
Mk5 General Area
