Author Topic: Electronics Gurus!  (Read 2877 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=1jfavocd2njn6hdhghoak9j5nl&/topic,19740.0.html
Electronics Gurus!
« on: April 15, 2011, 10:29:25 pm »
Ok.. here goes!
One of the LEDs has broken on my nixie clock.
Ive measured the voltage across the legs of the diodes. All measure 2.7-2.8V apart from the one that broken with reads about 1.4V.
Does this mean that its not illuminating becuase the voltage is too low, or is the low voltage reading a result of the broken diode?
Rich
Re: Electronics Gurus!
« Reply #1 on: April 15, 2011, 10:34:24 pm »
Sounds like it's not illuminating because the voltage is too low.
« Reply #2 on: April 15, 2011, 10:47:53 pm »
Hmmm... i just dont see why its not getting the voltage. As you can see they are all connected up in parallel so if one wasn't working due to a voltage problem i would imagine none of them would work.
 Need to take it to bits properly tomorrow to check for dry joints.
Offline PDT
  • -Receive: 142
« Reply #3 on: April 15, 2011, 10:58:27 pm »
Are you measuring the voltage with the diode still connected? If so, disconnect the diode and measure voltage.
« Reply #4 on: April 15, 2011, 10:59:22 pm »
Yes the diode is still connected up.
« Reply #5 on: April 15, 2011, 11:02:27 pm »
If it's the blue LED then it could just be the diode that's failed.
« Reply #6 on: April 15, 2011, 11:04:50 pm »
Hedge.. D11-D16 on that diagram are the LEDs
Offline PDT
  • -Receive: 142
« Reply #7 on: April 15, 2011, 11:06:04 pm »
In that case its the diode pulling the voltage down.
Offline cmdrfire
    • Commander Fire - my blog
« Reply #8 on: April 15, 2011, 11:06:46 pm »
Do you have a multimeter?
What resistance do you measure across the resistor? Check also for conduction across the LED if you have multimeter that can do diodes.
Unlikely to be an LED failed unless it's been subject to high temperature for an excessive time while you were soldering (which can result in an eventual failure); more likely cause is a dry joint I'd guess.
edited 'cos i didn't see you measured voltage across the LED
« Reply #9 on: April 15, 2011, 11:10:54 pm »
I know.  :wink:
« Reply #10 on: April 15, 2011, 11:20:44 pm »
Tested all LEDs with the Diode setting. The one that is broken gives a reading about  300... the working ones read 1500ish
Sorry hedge... internetz missunderstanding!  :smiley:
Rich
Offline Janner_Sy
  • -Receive: 113
« Reply #11 on: April 15, 2011, 11:29:59 pm »
im no electronics guru, i do big power, but ive dabbled with elctronics at Uni, id bet its as PDT says,  to much heat cause and a poor connection/solder issue and will cause a volt drop over that diode.
Offline cmdrfire
« Reply #12 on: April 16, 2011, 12:16:43 am »
Rich
Solution replace LED :P
Offline JackG
  • -Given: 33
  • -Receive: 31
    • Distinct Detailing
« Reply #13 on: April 16, 2011, 07:41:09 am »
Ok, what the hell is that clock all about??? I want one......but there expensive! Seem to be half built on eBay? Why does it look so funny??  :popcornsoda:
www.distinctdetailing.co.uk
« Reply #14 on: April 16, 2011, 10:58:00 am »
Thank neo.  :happy2: Must have just been a dodgy component.
JackG... What the hells is it all about??? Its a clock!  :signLOL:  (i saw cmdrfires and had to have one)
Rich
