Author Topic: Fitting LED Sidelights  (Read 15186 times)
Re: Fitting LED Sidelights
« Reply #15 on: July 24, 2012, 10:21:24 pm »
Time to replace mine, I've bought a new set as one has an intermittent fault but I am really struggling to get out the drivers side, when I did the original set, VW even struggled doing it as well!
I struggled cos I tried with my fingers at first....and cos I wasn't sure whether or not to twist em out!!!
Pliers and a good straight yank back (no twisting) will get em out.  :happy2:
Offline Kalpsn2000
  • -Receive: 56
« Reply #16 on: July 27, 2012, 12:03:28 pm »
Yes first time it tried to change that one I ended up with lots of cuts and bruises due to the lack of space and it was on really tight.
Offline maxload
  • -Given: 41
  • -Receive: 29
  • Edition30 - No.1819
« Reply #17 on: July 27, 2012, 01:58:10 pm »
Drivers side is really tight for space. I cut my knuckles in several places trying to do it. But eventualy they do come out with a hard pull and lots of blood and sweat later.
Offline ali6n2
« Reply #18 on: July 27, 2012, 07:43:13 pm »
Try using the thin nosed pliers. I found it much easier
Offline Obbzi
« Reply #19 on: August 01, 2012, 08:21:39 pm »
Had another go at the weekend and failed! :ashamed: Could not do the passenger side at all, cant get anything in there even long nose pliers its really doing my head in!
And then the drivers side is a doddle but the new LED fell out inside the light!
Any ideas how I can get it out without removing the whole unit?
How do you remove the light is it all the bumper off?
Offline david25
  • -Given: 19
« Reply #20 on: August 02, 2012, 05:07:07 pm »
Rubber gloves (used for dish washing) are great here and allow you to get a better grip, they still dont stop the swearing though!
Offline ali6n2
« Reply #21 on: August 02, 2012, 05:21:48 pm »
As a last resort take bumper off and remove the lights. Might need a kid or someone with small hands
Offline Obbzi
« Reply #22 on: August 06, 2012, 04:22:55 am »
How hard is it to take the bumper off? And how hard is it to put back on?
Offline Kalpsn2000
  • -Receive: 56
« Reply #23 on: August 06, 2012, 12:12:19 pm »
Lot of work just for changing the bulbs IMO. Although that is your only option now the bulb has fallen inside.
First time I changed the drivers side I did unbolt and move the black box thats sits directly behind the headlight which gave me enough room to get the bulb out :happy2:
The passanger side was easier as there is more room on that side.
« Last Edit: August 06, 2012, 12:14:43 pm by Kalpsn2000 »
ReeceH13
« Reply #24 on: July 10, 2014, 12:41:35 pm »
Sorry to resurrect, but, does anyone know if these http://www.ebay.co.uk/itm/2x-501-CREE-ERROR-FREE-CANBUS-LED-SMD-NUMBER-PLATE-XENON-WHITE-BULBS-T10-W5W-194-/380905335965?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58afba2c9d#ht_5398wt_902 will fit the sidelight bulb holders? I take it I won't need a resistor? Any help will be appreciated   :happy2:
Offline paulw123
  • -Receive: 47
« Reply #25 on: July 10, 2014, 04:02:30 pm »
fitted these in mine
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=321414444554
the problem with Mk5 is that the bulb has to fit down a very tight tube, oh and they are a bugger to fit  :fighting:
ReeceH13
« Reply #26 on: July 10, 2014, 06:52:09 pm »
Thanks for that mate! Did you need to use a resistor pack with these?
 :smiley:
Offline paulw123
  • -Receive: 47
« Reply #27 on: July 11, 2014, 01:02:12 pm »
no they were plug & play, no different to fitting normal dim bulbs.
Offline Leonpettit
  • 2008 Edition 30 DSG - No.1706
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89470.msg905534.html#msg905534
« Reply #28 on: July 11, 2014, 04:17:14 pm »
Have you got any pictures fitted paul?
Mods coming soon...
Offline Spankiee
  • -Receive: 20
« Reply #29 on: July 11, 2014, 04:40:28 pm »
just wiggle them up and down instead of a straight pull. worked a treat on mine.
bumper off to replace sidelights bulbs   :confused:
candy white edition 30
