All Things Mk5 > Superchips Zone
Bluefin Stage 2
<< < (11/11)
liver:
i emailed bluefin today stating my boost figures and explaining the dip in power also showing them my graph
here is there response
Hi Mark
These boost figures are low, we would expect the engine to be running 17-18 psi with the stage 2 file. I would suspect that you have a tear in the diaphragm in your dump valve, I suspect this as you turbo is able to produce more boost with the higher load that are achieved using the higher gears and we also come across the issue quite often on the VW Cup cars that we tune.
The dump valve is incorporated into the Turbo, this is on the back of the engine and is most easily accessed from underneath with the vehicle on a ramp.
I hope this helps
Regards
Dave
ive already changed the dumpvalve so it can't be this, but at least i now know i am not boosting correctly. PCV fix will hopefully fix this
im doing some data logging tonight so will post up the results when ive done those, as i wont know what they are showing lol
liver:
didnt get chance to do any data logging
recieved my bsh stage 1 fix this morning so will try and get that fit asap and hope this is the problem
if not i will try and data log
liver:
Here's a pic of the broken PCV.
You can see the check valve inside is broken, the circular piece should be centred, but its broken a loose and never creates a seal.
hopefully the car should boost better now, i think im gonna try re-installing the software too, just because the last time it was installed the car had just gone crazy and imobolised itself etc, just for piece of mind really, few days standard then back to stage 2
liver:
put the car back on the standard map and the car is pretty much boosting the same as it was previously
will try n get logs in standard mode then with the map on to compare
liver:
sorted the logging out
here are the logs, remember the car is on the standard map, will also log 2mora when the map is back on to show the differences
   Group A:   '002            Group B:   '106            Group C:   '115
      Engine Speed   Engine Load   Injection   Intake Air Mass      Fuel Rail   Electrical   Electrical   Time      Engine Speed   Engine Load   Boost Pressure   Boost Pressure
   TIME         Timing      TIME   Pressure   Fuel Pump 1   Fuel Pump 2      TIME         (specified)   (actual)
Marker   STAMP    /min    %    ms    g/s   STAMP    bar    %       s   STAMP    /min    %    mbar    mbar
   0.11   2360   121.8   4.08   68.56   0.24   109.4   55.7       655.35   0.01   2360   121.1   1720   1470
   0.51   2520   130.1   4.59   75.44   0.63   109.4   56.9       655.35   0.36   2440   127.1   1740   1590
   0.88   2640   139.1   4.84   81.17   1.02   110.1   57.6       655.35   0.75   2600   137.6   1780   1740
   1.27   2760   144.4   5.1   87.97   1.4   109.4   58.8       655.35   1.14   2720   142.9   1770   1820
   1.66   2920   145.9   5.1   89.97   1.78   110.7   58.8       655.35   1.54   2840   145.9   1760   1830
   2.05   3040   144.4   5.1   91.69   2.17   108.8   59.6       655.35   1.91   3000   144.4   1750   1780
   2.42   3160   143.6   5.36   97.22   2.57   110.1   60.4       655.35   2.3   3120   143.6   1740   1750
   2.81   3320   143.6   5.61   101.42   2.94   109.4   60.8       655.35   2.69   3240   143.6   1730   1740
   3.2   3440   143.6   5.61   105.94   3.33   108.2   61.6       655.35   3.08   3400   142.9   1720   1740
   3.6   3560   143.6   5.61   106.86   3.72   108.8   62       655.35   3.45   3520   143.6   1720   1750
   3.97   3680   139.1   5.36   108.89   4.11   110.7   61.6       655.35   3.84   3640   139.8   1710   1690
   4.36   3800   139.1   5.36   112.97   4.48   108.2   62.4       655.35   4.23   3760   139.8   1700   1700
   4.75   3920   139.1   5.36   115.75   4.88   110.7   63.5       655.35   4.63   3880   139.8   1700   1690
   5.14   4040   139.1   5.36   120.33   5.26   108.8   63.5       655.35   5   4000   139.8   1690   1680
   5.51   4160   139.8   5.61   122.81   5.65   109.4   64.3       655.35   5.39   4120   139.1   1690   1680
   5.9   4240   141.4   5.87   130.92   6.03   110.1   65.1       655.35   5.78   4240   140.6   1690   1680
   6.29   4360   142.1   5.87   133.47   6.42   109.4   65.5       655.35   6.17   4320   141.4   1690   1680
   6.68   4480   142.9   6.12   138.31   6.81   109.4   66.3       655.35   6.54   4440   142.9   1690   1680
   7.06   4560   144.4   6.12   142.22   7.2   108.2   67.5       655.35   6.93   4560   144.4   1680   1670
   7.44   4680   144.4   6.12   144.58   7.58   110.1   67.5       655.35   7.32   4640   144.4   1680   1670
   7.84   4800   143.6   6.12   145.61   7.96   108.8   67.1       655.35   7.71   4760   143.6   1680   1660
   8.23   4880   143.6   6.12   148.58   8.35   110.1   67.8       655.35   8.09   4840   142.9   1670   1680
   8.6   4960   142.1   6.12   150.11   8.74   110.1   68.2       655.35   8.48   4960   141.4   1670   1660
   8.99   5080   142.9   6.12   154.97   9.12   108.8   68.6       655.35   8.87   5040   142.1   1660   1660
   9.38   5160   142.9   6.12   156.56   9.51   108.2   68.6       655.35   9.26   5120   142.1   1630   1670
   9.77   5240   139.8   6.12   154.97   9.9   108.2   69.4       655.35   9.63   5200   141.4   1610   1640
   10.15   5320   136.1   5.87   155.31   10.29   110.1   69.8       655.35   10.02   5280   137.6   1600   1600
   10.54   5400   133.8   5.87   154.11   10.66   112   68.6       655.35   10.41   5360   135.3   1490   1580
   10.93   5440   83.5   3.06   84.83   11.05   113.3   58.8       655.35   10.81   5440   109   1040   1620
   11.32   5520   104.5   4.08   129   11.44   108.8   62.7       655.35   11.18   5520   101.5   1500   1200
   11.69   5600   119.5   5.1   157.89   11.83   108.2   62.7       655.35   11.57   5560   115   1530   1350
   12.08   5600   103   4.34   113.75   12.21   111.4   63.1       655.35   11.96   5640   92.5   1430   1450
   12.47   5680   106.8   4.34   132.25   12.59   109.4   64.7       655.35   12.35   5680   106   1460   1240
   12.86   5760   118.8   5.1   148.44   12.99   105.6   67.8       655.35   12.72   5720   115.8   1310   1360
   13.24   5840   115.8   4.84   139.06   13.38   115.2   63.5       655.35   13.11   5800   120.3   1250   1410
   13.63   5840   78.2   2.81   85.81   13.75   110.1   60       655.35   13.5   5840   78.2   930   1460
   14.02   5920   100.8   4.08   129.97   14.14   105.6   64.3       655.35   13.89   5880   97.7   1290   1170
   14.41   5960   105.3   4.34   136.64   14.53   110.7   65.9       655.35   14.27   5960   103   1440   1210
   14.78   6000   117.3   5.1   157.69   14.92   102.4   69.4       655.35   14.65   6000   112.8   1440   1300
   15.17   6080   130.8   5.87   173.89   15.3   108.8   70.2       655.35   15.05   6080   127.8   1430   1490
   15.56   6160   132.3   5.87   172.5   15.69   110.1   70.2       655.35   15.44   6120   133.1   1420   1520
   15.95   6200   125.6   5.61   165.83   16.08   109.4   69.8       655.35   15.81   6200   127.8   1410   1460
   16.32   6280   121.8   5.36   163.22   16.47   108.2   69.8       655.35   16.2   6280   121.8   1400   1430
   16.71   6360   121.1   5.36   162.78   16.84   109.4   69.8       655.35   16.59   6320   121.1   1380   1410
   17.1   6400   118.8   5.1   160.78   17.23   111.4   70.6       655.35   16.98   6400   119.5   1370   1390
   17.49   6440   116.5   5.36   161.58   17.62   106.2   69.8       655.35   17.35   6440   116.5   1350   1380
   17.87   6520   117.3   5.36   163.64   18.01   110.7   70.2       655.35   17.74   6480   118.8   1350   1370
   18.28   6560   115   5.1   161.31   18.4   112.6   69.8       655.35   18.14   6560   117.3   1340   1350
   18.66   6640   113.5   5.1   160.58   18.79   107.5   69.4       655.35   18.54   6600   113.5   1330   1330
   19.06   6680   112.8   4.84   160.47   19.18   113.9   69.4       655.35   18.91   6640   113.5   1270   1330
   19.43   6720   110.5   4.84   159.61   19.57   113.3   69.4       655.35   19.3   6720   111.3   1250   1300
   19.82   6720   106   4.59   151.58   19.95   114.6   67.8       655.35   19.69   6720   108.3   1200   1260
Saturday   21   May   2011   18:12:42:29760   VCDS Version: Release 10.6.4   Data version: 20110418
1K0 907 115       2.0l R4/4V TFSI  00 0070
   0.2   2320   151.1   5.36   84.36   0.33   109.4   56.5       655.35   0.06   2240   142.9   1850   1830
   0.58   2400   166.2   5.87   90.64   0.72   109.4   58.4       655.35   0.45   2360   163.9   1820   2070
   0.97   2520   160.2   5.87   81.83   1.09   109.4   57.3       655.35   0.84   2520   163.9   1800   2060
   1.36   2640   145.1   5.1   78.22   1.48   110.7   56.5       655.35   1.24   2600   148.9   1790   1860
   1.75   2760   140.6   5.1   82.83   1.87   110.7   56.5       655.35   1.61   2720   141.4   1780   1780
   2.12   2840   140.6   5.1   85.47   2.27   110.1   57.6       655.35   2   2840   141.4   1770   1780
   2.51   2960   141.4   5.36   90.28   2.64   110.1   58.8       655.35   2.39   2920   140.6   1760   1770
   2.9   3080   142.1   5.61   94   3.03   110.1   58.8       655.35   2.78   3040   142.1   1750   1770
   3.29   3160   142.9   5.61   96.97   3.42   109.4   59.2       655.35   3.15   3120   142.9   1740   1750
   3.66   3280   142.1   5.61   101.58   3.81   109.4   59.6       655.35   3.54   3240   142.1   1730   1740
   4.05   3400   142.9   5.61   104.28   4.18   110.1   60       655.35   3.93   3360   143.6   1720   1750
   4.45   3480   141.4   5.61   105.47   4.57   110.1   60.4       655.35   4.32   3440   142.1   1720   1730
   4.84   3560   142.1   5.61   108.75   4.97   109.4   60.4       655.35   4.7   3560   142.1   1710   1730
   5.21   3680   139.8   5.36   109.78   5.35   110.1   60.8       655.35   5.09   3640   140.6   1710   1710
   5.6   3760   136.1   5.36   109.89   5.72   110.7   60.8       655.35   5.48   3760   136.8   1700   1670
   5.99   3880   137.6   5.36   115.22   6.12   110.1   61.6       655.35   5.87   3840   136.8   1690   1680
   6.38   3960   137.6   5.36   116.83   6.51   110.1   61.2       655.35   6.24   3920   137.6   1690   1680
   6.76   4080   138.3   5.36   120.44   6.9   109.4   62.7       655.35   6.63   4040   138.3   1680   1690
   7.14   4160   139.1   5.61   123.83   7.27   107.5   63.1       655.35   7.02   4120   139.1   1680   1690
   7.53   4280   139.1   5.61   125.92   7.66   110.7   63.5       655.35   7.41   4240   139.8   1680   1670
   7.93   4360   139.1   5.61   129.94   8.05   110.7   64.3       655.35   7.79   4320   139.8   1680   1670
   8.3   4480   142.1   5.87   134.42   8.44   109.4   65.1       655.35   8.17   4440   140.6   1680   1670
   8.69   4560   142.1   5.87   139.92   8.81   110.1   66.3       655.35   8.56   4520   142.9   1680   1660
   9.08   4640   141.4   6.12   140.64   9.2   110.1   67.1       655.35   8.96   4640   141.4   1670   1660
   9.47   4760   142.1   6.12   145.22   9.6   110.1   67.1       655.35   9.33   4720   142.1   1670   1660
   9.84   4840   140.6   5.87   145.64   9.99   110.1   67.1       655.35   9.72   4800   141.4   1670   1650
   10.23   4920   139.8   5.87   147.94   10.36   111.4   67.5       655.35   10.11   4920   141.4   1660   1660
   10.62   5000   141.4   5.87   153.78   10.75   108.2   67.8       655.35   10.5   5000   142.1   1660   1670
   11.02   5120   141.4   6.12   152.75   11.14   108.2   67.8       655.35   10.87   5080   141.4   1640   1670
   11.39   5200   139.1   5.87   152.94   11.53   110.7   68.2       655.35   11.27   5160   139.1   1620   1640
   11.78   5280   136.8   5.87   153.17   11.9   109.4   67.8       655.35   11.65   5240   136.8   1600   1600
   12.17   5360   134.6   5.87   155.36   12.29   111.4   68.2       655.35   12.05   5320   135.3   1580   1590
   12.56   5440   135.3   5.87   156.42   12.69   109.4   68.2       655.35   12.42   5400   134.6   1560   1590
   12.94   5520   132.3   5.61   156.03   13.08   110.7   68.2       655.35   12.81   5480   133.1   1550   1560
   13.32   5600   131.6   5.61   156.42   13.45   106.9   68.2       655.35   13.2   5560   131.6   1530   1530
   13.71   5680   129.3   5.61   156.75   13.84   110.7   68.2       655.35   13.59   5640   130.1   1520   1520
   14.11   5760   129.3   5.61   159.47   14.23   109.4   68.2       655.35   13.96   5720   130.1   1500   1510
   14.48   5800   128.6   5.61   158.94   14.62   108.8   68.6       655.35   14.35   5760   128.6   1490   1490
   14.87   5880   127.8   5.36   160.78   14.99   111.4   69       655.35   14.74   5840   126.3   1470   1490
   15.26   5920   127.8   5.61   160.78   15.38   108.2   69       655.35   15.13   5920   126.3   1460   1470
   15.65   5960   126.3   5.36   163.03   15.77   110.7   69       655.35   15.51   5960   126.3   1450   1460
   16.03   6040   125.6   5.36   162.75   16.16   110.1   69       655.35   15.9   6040   125.6   1440   1450
   16.41   6120   122.6   5.36   158.56   16.53   110.7   69       655.35   16.29   6080   122.6   1430   1440
   16.8   6160   121.8   5.36   161.86   16.93   108.8   69.4       655.35   16.68   6160   122.6   1420   1430
   17.19   6200   121.1   5.36   161.89   17.32   110.1   69.4       655.35   17.05   6200   121.8   1410   1420
   17.56   6280   119.5   5.1   161.19   17.71   110.1   69.4       655.35   17.44   6280   120.3   1400   1410
   17.96   6320   118.8   5.36   159.25   18.08   110.7   69.4       655.35   17.83   6320   119.5   1390   1400
   18.35   6400   118   5.36   161.19   18.47   112   69.8       655.35   18.23   6360   117.3   1380   1390
   18.74   6440   118.8   5.36   163.53   18.86   110.7   69.8       655.35   18.6   6400   118   1370   1390
Navigation
[0] Message Index
[*] Previous page
Go to full version
