Author Topic: Engine hunting and tickover low. Poor running in general. HELP!  (Read 31102 times)
h4rdy
Ok I have an issue with my ED30 its started for no apparent reason with no warnings.
Its hunting, idle form 900rpm to 2000rpm, which is making the DSG play up as well.
Then the revs drop to nearly cut out.
I have pasted the VCDS scan below which says G247 sensor, I have also unplugged the MAF as per another post when I searched which did nothing but make it misfire and pop.
Any ideas, BDMAlex has helped but he is on Holiday so don't like to bother him too much :happy2:
G247 or Fuel Pump sensor on top next? Or neither?
3 Faults Found:
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 0
                    Fault Frequency: 17
                    Mileage: 108795 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:51:39
             Freeze Frame:
                    RPM: 1093 /min
                    Load: 22.3 %
                    Speed: 9.0 km/h
                    Temperature: 84.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.351 V
004243 - Bank 1; Fuel Measuring System 2: Malfunction
               P1093 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 110943 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:43:27
             Freeze Frame:
                    RPM: 1392 /min
                    Load: 12.9 %
                    Speed: 19.0 km/h
                    Temperature: 80.0°C
                    Temperature: 31.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
004506 - Fuel Pressure Sensor (G247): Malfunction
               P119A - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 110995 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:35:35
             Freeze Frame:
                    RPM: 784 /min
                    Load: 18.0 %
                    Speed: 3.0 km/h
                    Temperature: 82.0°C
                    Temperature: 23.0°C
                    Voltage: 14.224 V
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Engine hunting and tickover low. Poor running in general. HELP!
« Reply #1 on: May 22, 2011, 08:18:21 pm »
Is the oil filler cap on securely?
If you clear the codes do they come back??
Stu...
Offline TrickGTI
« Reply #2 on: May 22, 2011, 08:24:47 pm »
Faulty pcv?
2006 Tornado red GTI
h4rdy
« Reply #3 on: May 22, 2011, 08:26:40 pm »
Yes Stu the filler cap is secure and the codes come back immediately after you clear them.
Alex mentioned the fuel pump top sensor broke but I haven't been under there for that to happen.
But I will check tomorrow.
I drove it to work after a break and it was ok but then on the way home it just started.
h4rdy
« Reply #4 on: May 22, 2011, 08:27:31 pm »
Faulty pcv?
Trick, what does that stand for mate and where?
Offline TrickGTI
« Reply #5 on: May 22, 2011, 08:33:31 pm »
It's located at the front of the engine and it's up against the rocker cover and it has a circular top to it I'd link a pic but I'm on the I phone at the mo. When it tears like the dv's do As there is a diaphragm in it and it let's to much air into the intake side and causes that exact problem.  :happy2:
Offline TrickGTI
« Reply #6 on: May 22, 2011, 08:35:09 pm »
Also not sure what it stands for but it's a breather for the engine.
h4rdy
« Reply #7 on: May 22, 2011, 08:39:32 pm »
Is it in this picture?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #8 on: May 22, 2011, 08:41:48 pm »
A loss of pressure in the rocker cover etc can cause hunting.  Often the filler cap or PCV are causes of this.
It would appear you need to investigate the fuel system.
Have a look here -
G247 is the one to the front left of the engine (and not on top of the fuel pump), item 5.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: May 22, 2011, 08:42:06 pm »
Lol, beat me too it.
Stu...
h4rdy
« Reply #10 on: May 22, 2011, 08:45:31 pm »
I have thanked you all multiple times. Will look tomorrow.
J
Offline gazon69
« Reply #11 on: May 23, 2011, 12:23:17 pm »
run the engine for a couple of mins until the engine starts reving erratically then try to remove the oil cap, if this is difficult to do or you can't remove it at all then it's your Pcv.
Offline s3dubbin
« Reply #12 on: May 23, 2011, 12:31:33 pm »
Fuel pump sensor, mine done the exact same last year at the exact same revs. Stevie.
Offline cmdrfire
    • Commander Fire - my blog
« Reply #13 on: May 23, 2011, 01:10:49 pm »
Had a similar problem with mine (including progressively worse misfires/losing power under load) which was traced to that sensor. Went away when replaced, but just now started to come back  :scared:
h4rdy
« Reply #14 on: May 23, 2011, 01:21:44 pm »
Fuel pump sensor? Or g247?
