Author Topic: Engine hunting and tickover low. Poor running in general. HELP!  (Read 32593 times)
h4rdy
Re: Engine hunting and tickover low. Poor running in general. HELP!
« Reply #30 on: May 30, 2011, 10:07:42 am »
There is a Tiny hole on the end of the pcv. If the diaphragm has failed, then you will hear a small hissing sound as soon as you shut down the engine.
Sounds to me you have a faulty pcv too. £35 from memory for a new one.
I have a G247 turning up so ill try that first as I have bought it now.
Then ill buy a new pcv or get uncle visa out and buy a catch tank.
h4rdy
« Reply #31 on: May 31, 2011, 02:11:59 pm »
how did you check the diaphragm inside the pcv housing?? You have to break it open to look at it?
Do you get any sort of hissing sound when you shut the engine down from under the top engine cover?
No hissing noise when engine shut down.
Just to say I had to drive it today and its fine when driving just tickover is the problem.
I think this PCV thing is going to bite me in the ass! Because of this now:
2 Faults Found:
004506 - Fuel Pressure Sensor (G247): Malfunction
               P119A - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 111055 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:18:30
             Freeze Frame:
                    RPM: 914 /min
                    Load: 14.1 %
                    Speed: 0.0 km/h
                    Temperature: 84.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.208 V
008825 - Leak in Air Intake System
               P2279 - 002 - Lower Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 111055 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:19:42
             Freeze Frame:
                    RPM: 835 /min
                    Load: 16.1 %
                    Speed: 0.0 km/h
                    Temperature: 86.0°C
                    Temperature: 24.0°C
                    Voltage: 13.970 V
Readiness: 0000 0100
h4rdy
« Reply #32 on: June 03, 2011, 11:24:10 am »
Just got my G247 and its not what I thought it is.
So of the two pictures on page one, is my (BDMAlex) picture right or Stu?
Because what I have got is this:
Also where does it go if it is the right one anyone got an ETKA drawing for me :happy2:
h4rdy
« Reply #33 on: June 03, 2011, 11:25:32 am »
Oh and I have completely given up now!
Got better things to do TBH!
 :sad1:
h4rdy
« Reply #34 on: June 03, 2011, 05:35:47 pm »
Anybody changed one?
Offline vRSAlex
  • -Receive: 253
« Reply #35 on: June 03, 2011, 07:57:02 pm »
That's a map sensor mate.
Follow AKS tuning on Facebook
h4rdy
« Reply #36 on: June 03, 2011, 08:11:41 pm »
Alex is the G247 screwed into the rail near that RS4 valve mate?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #37 on: June 03, 2011, 08:12:06 pm »
Yep that's definitely a MAP sensor and not at all what you are looking for
Stu...
h4rdy
« Reply #38 on: June 03, 2011, 08:17:21 pm »
I am on the case from where I got it, thanks guys.
Its just not bloody happening.
Stonor is ruined for me this year now!
Unless I am prepared to sit in traffic at 500rpm coughing and spluttering!
Offline vRSAlex
  • -Receive: 253
« Reply #39 on: June 03, 2011, 10:03:29 pm »
Yep. But its easier to get to than the fuel return valve.
h4rdy
« Reply #40 on: June 04, 2011, 02:56:01 pm »
So got a bit of Mojo back today and rebuilt the fuel pump with a newer one and thought I had cracked it as found this:
But nope no good.
Newer one completely stripped and cleaned with solvent anyway so piece of mind and cam follower had no more wear than before so pleased with that too.
So then I replaced 4 coil packs with revision F as a precaution as mine were C.
So now I have to wait for G247 to arrive.
Hopefully next week it will be sorted.
Offline TrickGTI
« Reply #41 on: June 04, 2011, 03:51:45 pm »
A loss of pressure in the rocker cover etc can cause hunting.  Often the filler cap or PCV are causes of this.
It would appear you need to investigate the fuel system.
Have a look here -
G247 is the one to the front left of the engine (and not on top of the fuel pump), item 5.
sorry to thread jack but can you get part 7 seperate?
also you any closer to finding the problem ???
2006 Tornado red GTI
Offline bacillus
  • -Receive: 453
« Reply #42 on: June 04, 2011, 05:44:58 pm »
according to the guys on the vortex forum, you can't get part 7 seperately so try to get it off a redundant hpfp.
h4rdy
« Reply #43 on: June 06, 2011, 04:14:50 pm »
I am closer to sorting this problem because I have eliminated the fuel pump.
And no item 7 is not available seperately but you can pulse the solenoid via VCDS which I think BACILLUS told me so won't take his glory. See the other part of this thread.
Waiting for G247 now again.
h4rdy
« Reply #44 on: June 08, 2011, 07:50:48 pm »
Fixed :happy2:
So really the fuel pump I had was on its way out so pleased I rebuilt a used low mileage one before I fitted.
I changed the PCV as I was able to get hold of one before G247.
Then I obtained a G247 which solved it.
I then put the old PCV back on and it started again so the new one went back on and voila.
Some how G247 and PCV had failed!
Very pleased with myself for solving the problem, albeit took a while, which, wasn't a problem for me as its a toy!
The most difficult part was making a spanner for the G247 which isn't pretty (angle grinder!) but it worked!
Thanks for everybodys help.
