Just to update this.
Bearing in mind I have the OEM Xenons fitted.
I contact VW Customer services, as I'm still interested in this. Was advised of the following initially it would be like the MK6 Golf DRL's
only to be called back later with:
New light switch, still not to clear on what functions this has, but guessing the settings are:
OFF/ DRL/ Side Lights/ Dipped Lights(Xenons) + Front Fogs/Rear Fogs(As in the Audi's). VW appear to lose the setting for AUTO LIGHTS on the switch.
Software update (NOT a VCDS tweak) to the ECU(Power control ECU)?? Dealer would need to hook the car up to VAS and update the ECU from Germany.
With the switch in the DRL position ONLY the Xenons come on, no other lights.
Was advised although didn't seem to sure, the AUTO lights feature still works from this setting, so when required the lights auto switch on.
Disclamer was speak to the dealer
If customer services don't know exacty after speaking to thier "In House tech" what chances have the dealers got!
Got hold of the instructions off the web:
Installation instructions:
Continuous running light original retrofit kit
Set contents:
◆ 1 x Light switch
◆ 1 x Software certificate
◆ 1 x Installation instructions
Special tools, test and measuring equipment, and ancillaries required:
◆ Vehicle diagnostics, measurement and information system -VAS 5051A- with software version V15.94.00. or
higher
Procedure:
Note
◆ A competent workshop should install the continuous running light kit. Special tools and the accompanying
literature specific to the vehicle are required for fitting it. Incorrect fitting may lead to damage to the vehicle.
◆ To update the vehicle software, an online SVMVW connection and the appropriate password are needed.
◆ All rights to make technical changes reserved.
1.1 Replacing the light switch
− Remove the existing light switch and replace with the supplied light switch.
Electrical system; repair group 96; lights, lamps, switches - internal; lights and switches in the dashboard;
removing and fitting light switch E1
1.2 Updating the vehicle software
− Connect a vehicle diagnostics, measurement and information system -VAS 5051A- to the vehicle.
Electrical system, repair group 97; Wiring, vehicle diagnostics, measurement and information systems;
Connecting a vehicle diagnostics, measurement and information system -VAS 5051A-.
− Select the operating mode “Guided trouble shooting” within the vehicle diagnostics, measurement and
− After querying the control units, select the “Functions / component selection“ via the button “Jump” and then
sequentially the following menu options:
◆ Software version management
◆ Conversion/retrofitting campaign
− Enter the 5 character action code “302F1“.
The online connection is created after code entry and the software update carried out.
− After successful software updating, disconnect the connection to the vehicle diagnostics, measurement and
information system -VAS 5051A- and carry out operational testing of the continuous running light.
The attached certificate is to be filled in with the chassis number and fitting date by the workshop, signed and
stamped and then given to the customer when the vehicle is returned. The certificate acts as proof of purchase of
the product Continuous running light, while the workshop signature certifies to the customer that fitting has been
correctly carried out by Volkswagen.
1K0 052 431
3C8 052 431
