Hi Steve, looking good mate.
Dont forget to plug the rear washer water pipe, forgot to do mine and accidently squirted water into the rear parking censor cotrol box
When you get the cage fitted you will loose your seat belts, I had some Mk4 belts fitted. The roll cage prevents you having the roller in the door pillar recess but you can mount it outside, the full harness is great but a pain if your not on track.
I've got use to the steering wheel, but I can see what Mike is saying, I also needed the flat bottom as its easier to get in and out for me.
I've been looking into a large paddle on the left which shifts both up and down, similar to some WRC's, their not fitted to the wheel unlike the up/down shift buttons which work OK but are a bit hard to hit sometimes, the badge is a must.
Steve you forgot to take the templates at Bedford, I'll see you at Brunters or Combe.
