April 11, 2025, 04:05:42 pm
All Things Mk5
Technical Workshop
Boost Revo Stage 1 ED30
Topic: Boost Revo Stage 1 ED30 (Read 1381 times)
_Nathan_
Always Involved
-Given: 3
-Receive: 1
May 29, 2011, 06:12:34 pm »
Anyone know what the requested and actual boost is on an ED30 stage 1?
Also should requested fuel rail pressure really be 130 - can the stock HPFP even provide that (mine can't).
Last Edit: May 29, 2011, 10:32:27 pm by _Nathan_
E90 M3, E46 CSL Race car
Hedge
Just look at my post count
-Given: 484
-Receive: 304
Re: Boost Revo Stage 1 ED30
Reply #1 on:
May 31, 2011, 07:19:55 pm »
It depends on how long it is requesting it.
Put some of your logs up and someone clever not me can compare them with some 2+ logs.
chungster
-Given: 6
-Receive: 33
Reply #2 on:
May 31, 2011, 07:40:21 pm »
around 1.3-1.4 bar from memory.....
john_o
-Given: 136
-Receive: 108
Reply #3 on:
May 31, 2011, 08:47:12 pm »
I'd say you need to log other values too e.g. ignition delay to see what else is going on.
the boost levels seem a bit low tbh even for stage 1 (1300 mbar is about 19psi) where Im easily at 20+ (24 on guage) in the mid range.
but the revo are the experts....
Red ED35 5dr DSG
BLOG
BUILD
john_o
-Given: 136
-Receive: 108
Reply #4 on:
June 01, 2011, 12:13:57 pm »
my mid range is higher but my 6k value is lower
(ill go dig out the plots later tonight)
OEM all but the map.
130 bar from fuel pump should be achievable once its spinning above 4k rpm
let us know what REVO say
Red ED35 5dr DSG
BLOG
BUILD
All Things Mk5
Technical Workshop
